Old 11-16-2013, 05:46 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
Default Who ever figures out my problem I PAY!
OK guys I am going crazy here. I must be the only person with these codes. I getting p0152,p0158,p0151,p0138 p7034 and p1128. Let me give you guys detail on my setup. I had obx headers no cats with custom tune to turn off the rear. I also had both rear o2 codes when the rear o2 sensors were turned off. I had them plugged in and tried the non fouler trick still. So a few weeks ago bought the arh header with cats same issue. I check the wires from the o2 connection to the pcm with a volt meter on and they showed no break in the line. Bought 4 brand new sensors 2 in the front 2 in the rear still. Went back to a 93 tune even with the cam still got the codes. I changed all my spark plugs because they were due same thing. I not worried about p7034 tranny shop has fix that one. Any input please if i forgot something ask i tell you.
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 11-16-2013, 06:02 PM
Gecko's Avatar
Gecko Gecko is offline
Vehicle: 2004 Quad Cab
Trim Level: SLT 4x4
Rep:221
Gecko has a spectacular aura aboutGecko has a spectacular aura aboutGecko has a spectacular aura about
Could just be a problem with your PCM
Supercharged, cammed, other things too!
Old 11-16-2013, 06:28 PM
Trim Level: st
Color: silver
Rep:68
Yea but wondering if I get a PCM the tunes to that PCM. Will I have to get the tuned again?
Need more ideas. Will buy new PCM soon
Old 11-16-2013, 08:33 PM
Trim Level: st
Color: silver
Rep:68
Bump. help I need to pass emissions.
Old 11-17-2013, 01:44 PM
Trim Level: st
Color: silver
Rep:68
Bump I don't know anything else I need more ideas
Old 11-17-2013, 02:21 PM
Gecko's Avatar
Trim Level: SLT 4x4
Rep:221
If you get reset the PCM to stock and then replace it with a new one the canned tunes should still work. I'm not sure about your custom tunes, but I don't really see why they wouldn't
Old 11-17-2013, 03:36 PM
Trim Level: st
Color: silver
Rep:68
I put it to basic 93 tune still had issues. What would be the difference between me going dodge them "flashing it the me going to a 93 sock tube then a different tune then buying new PCM
Old 11-17-2013, 04:09 PM
Gecko's Avatar
Trim Level: SLT 4x4
Rep:221
There may be a problem with the PCM itself. That's why changing the tune isn't helping. I'm not sure reflashing the PCM would help either but it may be worth a shot. I don't know how much a new PCM is but reflashing is $100 or so I believe.
Old 11-17-2013, 04:46 PM
Rep:2705
just remember, that if you are getting a Code, it doesn't necessarily mean that the sensor where the reading is causing the code, it could be almost anything before the sensors location that could cause the fault code
P0138 1/2 O2 Sensor Shorted To Voltage
P0151 2/1 02 Sensor Shorted To Ground
P0152 2/1 02 Sensor Shorted To Voltage
P0158 2/2 02 Sensor Shorted To Voltage
__________________________________________________ ____
P1128 Dodge - Closed Loop Fueling Not Achieved Bank 1
Possible causes
- Fuel delivery system
- Manifold Absolute Pressure (MAP) sensor or wiring connectors
- O2 sensor wiring or connectors
- Engine mechanical system
- Faulty Powertrain Control Module (PCM)
P1128 Dodge Description
The Powertrain Control Module (PCM) detects a condition where the vehicle has remained in open loop fuel control, from a start-up condition, longer than a calibrated amount of time, when conditions would have otherwise closed loop operation.
the strange thing is, it could be caused by something like a sticking thermostat
Old 11-17-2013, 06:34 PM
Trim Level: st
Color: silver
Rep:68
so what are you trying to say yankee it could be anything.
