Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion > Nitrous Discussion
Nitrous Discussion Questions and Answers regarding adding Nitrous Oxide to your Dodge Ram.
Old 11-17-2013, 11:47 AM
USAF Long's Avatar
USAF Long USAF Long is offline
Vehicle: 2013 Ram 1500 RCSB
Rep:69
USAF Long will become famous soon enough
Send a message via AIM to USAF Long
Default Would this work on our trucks?
http://www.shophemi.com/p-1191-hemi-...injection.aspx
I don't see why it wouldn't but it looks like the best bet for a larger throttle body and the ability to add nitrous. Its pricey, but you can then piece together your nitrous system or order a plate system minus the plate.
I want to add nitrous next summer probably a 150 shot if I can get the timing reduced with a diablo tuner. Otherwise I'd stick at around a 100 shot.
-Scott Long-
2013 Ram Express RCSB: 5% tint, de-badged doors, muffler delete y-pipe, K&N panel filter.
Best Run: 14.60@96mph with 2.4 60' at Kil-Kare Raceway in Ohio
Old 11-17-2013, 02:10 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
Friend of mine has one on his 392 Magnum. Make sure it fits you're Ram. Honestly don't think you need it, just put the spray in front of the throttle body. If you spray a 100 shot, 1 range colder plug gapped .35 and run 93 octane on a canned 89 or 87 tune, even Super Chip tuner is ok. For a 150 shot, I'd want a fuel pressure gauge, a wideband O2 sensor installed and monitor knock retard with a Diablo tuner. I'd at least run the Sonnax line booster on my transmission. 150 shot is on the edge for stock internals hemi, stock transmission and stock fuel pump. You don't want to find you are running out of fuel under spray. You might check out the " Brisk plugs" for spray.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 11-17-2013, 03:01 PM
USAF Long's Avatar
Rep:69
I am not sure if the sonnax booster will work with my truck since I have the six speed and they say they are for the 5-speed. I mean technically its the same transmission with different programming but I want to be sure before I order it.
I could always upgrade the pump and get a custom tune I suppose. Maybe I'll stick with a 100 shot. I was looking at a plate system instead of a single nozzle but I also want a bigger throttle body, this would kill 2 birds with one stone.
-Scott Long-
Old 11-17-2013, 04:31 PM
Rep:2657
one of the members typed that he used a throttle body spacer to plumb in his nitrous
Old 11-18-2013, 12:26 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
I did.. tb spacer came with an ebay cai i bought years ago...
Old 11-23-2013, 11:21 AM
jerseymike's Avatar
jerseymike jerseymike is offline
Vehicle: 2013
Rep:116
jerseymike will become famous soon enoughjerseymike will become famous soon enough
I have a 2013 Ram 6 speed and the Sonnax works great. Simple plug and play. I ran it for 4 months till I got a custom HF tune then I took it off and sold it.
Old 01-23-2014, 04:30 PM
USAF Long's Avatar
Rep:69
I bought the Sonnax and of course it gets delivered right after I got back from the shop where I had my truck up on a lift to do my oil change. I will have to wait til it dries up outside from the melting snow or maybe throw a towel down under the truck.
I might pick up this throttle body when I get my taxes filed.
-Scott Long-
