Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Place your Ad Here!
Old 11-17-2013, 11:31 PM
zxtuner85's Avatar
zxtuner85 zxtuner85 is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT Laramie
Rep:2
zxtuner85 is on a distinguished road
Default 05 Interior light issues
Okay, so I have been searching for an answer for 2.5 hours. My issue is that when it gets cold outside...like 40 or lower, the interior dome lights in my truck do not work. After the truck warms up and I have the heat on for a little while one of the maps lights usually will start to work. Most of the time however they remain non-functioning. It does not matter how I try to turn them on the lights will not work. It effects both map lights and the dome light. I have upgraded to LED lights and in the warmer weather they work just fine. All of the fuses are good and the lights have good connections. As I mentioned, when it is warm I have no issues. Any help would be great.
Old 11-18-2013, 08:38 AM
tjbiker031's Avatar
Vehicle: 2002 Dodge Ram
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
Well it is possible for LED's to have a specific operating range.
What comes to mind to verify if its the LED's or anther issue is to find the positive and negitive wire and probe them with a multimeter while the LED's are pluged in. (you may have to rig jumer wires). And make sure the dimmer switch isnt resticting the operation of the light.
I would find a good ground away from the light (dont move it) and probe Positive wire going into light. Should see 12v (roughly) and then move the red led (dont move ground) to the ground. Should see 0v. Now place red lead on the positive wire and black lead on the ground you just checked and you should see source reading from orginal test
Do this when cold, and then when warm as you can get it. The whole test takes literally 30 seconds each.
Like i said before it may be the led's that were used and they are highly suspect
Old 11-27-2013, 11:38 PM
Simple guy Simple guy is offline
Vehicle: 2003 Ram 1500
Trim Level: SLT QC 4x4
Color: Mineral grey
Rep:109
Simple guy will become famous soon enoughSimple guy will become famous soon enough
or put the stock bulbs in and if they work you know it was the op range of the leds
