Old 11-18-2013, 07:00 AM
Big Al23's Avatar
Big Al23 Big Al23 is offline
Trim Level: Outdoorsman
Rep:40
Big Al23 is on a distinguished road
Default One thing I miss!
I know I'm going to miss the all wheel drive option. My previous Trailblazer and Silverado both had the all wheel drive on the selector. I used this option more so than 4 wheel. Anyone else miss that?
Old 11-18-2013, 07:11 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
I drive a 2 wheel drive, and when I had 4X4 the only time I used it on my Sonoma was when I tried to jump out into traffic with the crappy General tires that were OEM.
Doesn't the RAM have an "auto" function built into the transfer case?
Exco
Bill
Old 11-18-2013, 07:48 AM
Asur Asur is offline
Vehicle: .
Rep:4373
Exco
Not all have 4x4 auto, the higher end models usually all have them but the lower end ones don't
Old 11-18-2013, 02:03 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1195
Its optional on SLT's, and the Big horn/Lonestar, standard on any models above that.
US ARMY-RETIRED
2015 Ram 1500 Laramie 4x4 Crew in Blue Streak Metallic Pearlcoat-Mopar spray-in Liner, Mopar Mud Flaps, 20% tint, Mopar Side Steps, Best-Top Tri-Fold Bed Cover, DZ Tailgate assist.
2002 Ford Focus ZTW Wagon-loaded, tinted and tunes. 183k miles and counting...
Old 11-18-2013, 04:26 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
I have a Outdoorsman 4X4 and no auto 4 wheel drive. I wanted to have the choice in selecting when I wanted the 4 wheel drive to work.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 11-18-2013, 04:50 PM
Thunderhorse's Avatar
The Sound of Eight Hooves
Rep:545
Thunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of light
4wd auto is not the same as AWD. AWD can vary power to each of the 4 wheels, usually through a center differential. 4wd auto runs your truck in 2wd until the rear slips, and the front wheels kick in. It works in a sort of similar manner to AWD, but cannot vary power to all of the wheels; it can only vary power to each wheel per axle since there is a differential for the front and one in the rear. Both driveshafts are locked via the transfer case, so it can vary power between the front right and front left wheels for example, but unlike AWD it cannot vary power between the front left and rear right wheels.
That's why AWD can be driven on dry paved roads, but 4wd can't unless its in auto in which case you will really be in 2wd to prevent binding the transfer case.
Thunderhorse-Built: 25 Feb 2013 Warren, Michigan; Bought: 28 May 2013
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread), Borla XR-1 (thread), Matte black Plasti-dipped center console bezel, BT catch can.
Old 11-18-2013, 07:10 PM
BravoFoxtrot BravoFoxtrot is offline
Vehicle: 2013 Ram 1500 Sport Crew Cab
Color: Mineral Gray
Rep:42
BravoFoxtrot is on a distinguished road
Yep.
From the 2013 Ram 1500 owner's manual:
Electronically Shifted Transfer Case
(Five-Position Switch) – If Equipped
This is an electronic shift transfer case and is operated by
the 4WD Control Switch (Transfer Case Switch), which is
located on the instrument panel.
This electronically shifted transfer case provides five
mode positions:
• Two-wheel drive high range (2WD)
• Four-wheel drive automatic range (4WD AUTO)
• Four-wheel drive lock range (4WD LOCK)
• Four-wheel drive low range (4WD LOW)
• Neutral (NEUTRAL)
This electronically shifted transfer case is designed to be
driven in the two–wheel drive position (2WD) or fourwheel
drive position (4WD AUTO) for normal street and
highway conditions on dry hard surfaced roads). Driving
the vehicle in 2WD will have greater fuel economy
benefits as the front axle is not engaged in 2WD.
For variable driving conditions, the 4WD AUTO mode
can be used. In this mode, the front axle is engaged, but
the vehicle’s power is sent to the rear wheels. Four-wheel
drive will be automatically engaged when the vehicle
senses a loss of traction. Because the front axle is engaged,
this mode will result in lower fuel economy than
the 2WD mode.
When additional traction is required, the transfer case
4WD LOCK and 4WD LOW positions can be used to lock
the front and rear driveshafts together forcing the front
and rear wheels to rotate at the same speed. This is
accomplished by rotating the 4WD Control Switch to the
desired position. Refer to “Shifting Procedure” for specific
shifting instructions. The 4WD LOCK and 4WD
LOW positions are designed for loose, slippery road
surfaces only. Driving in the 4WD LOCK and 4WD LOW
positions on dry hard surfaced roads may cause increased
tire wear and damage to the driveline components.
NOTE: The transfer case NEUTRAL position is selected
by depressing the recessed button located on the lower
left hand corner of the 4WD Control Switch. The transfer
case NEUTRAL position is to be used for recreational
towing only. Refer to “Recreational Towing” in “Starting
and Operating” for further information.
