Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 11-26-2013, 05:52 PM
PowPow's Avatar
PowPow PowPow is offline
Vehicle: 1989 Ram LE 150
Trim Level: alot
Color: two tone red white
PowPow is on a distinguished road
Well i jumped it. And it starts hard then will die as soon as i let off the gas.
Dafaq
Old 11-27-2013, 02:15 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
So it will only start with throttle applied? Light or heavy throttle? Does it run steady when throttle is applied.? Depending on your anwers, it could just be an issue with the Idle Speed Control Actuator.
Old 11-27-2013, 12:18 PM
PowPow's Avatar
Trim Level: alot
It will start without throttle but will die quickly. As soon as i take my foot off it will stumble and die. But if i hold my foot on the gas it will rev high without trouble. Once i take my foot off theres no stopping the the shut off. I cant bring it back no matter how hard i try lol
Is that the plastic piece that connects to the throttle plate?
Old 11-28-2013, 11:39 PM
PowPow's Avatar
Trim Level: alot
I should specify i do not give throttle when i start. Once its started i floor it. Once i pull my foot off even a little bit the engine dies.
injectors, regulator, too much fuel
