Old 11-19-2013, 05:03 PM
Svety Svety is offline
Vehicle: 2010 Ram 1500 4x4
Trim Level: Cool Chrome Big Horn
Color: Cool Vanilla
Svety is on a distinguished road
Default Question on the TIPM
Does the TIPM on a 2010 replace the FCM on earlier Rams?
Old 11-19-2013, 06:52 PM
dbuzz77's Avatar
dbuzz77 dbuzz77 is offline
Vehicle: 2009 Ram RCSB 4x4
Color: Stone White
Rep:100
dbuzz77 will become famous soon enoughdbuzz77 will become famous soon enough
it replaces the body control module, if that's what you mean
2009 RCSB Sport, SC Cortex, K&N air box, all Amsoil fluids, Fan delete, Grounded TB, homemade catch can, homemade gps mount, Fastman TB, EZ down tailgate, Bully hitch step
Then God made a hemi, and knew that it was good.
Old 11-19-2013, 07:45 PM
Color: Cool Vanilla
No, the Front Control Module. I have seen on posts on older generation Rams that there were many electrical problems caused by a bad Front Control Module. I am having a few of those electrical issues. I searched for the FCM, a silver box attached to the fuse box, with no luck. I thought maybe this module was replaced by the TIPM, since I couldn't find it where other posts said to look.
Old 11-19-2013, 08:07 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Yes, many of the FCM controls are now integrated into the TIPM unit. Things such as lights, horn, etc. I think it all got integrated together in the 4th gen models. The older Rams also have a TIPM but they also had an FCM unit. Actually I think 06-08 had the FCM integrated to the TIPM also. Prior to 06, 02-05 the TIPM unit was called an IPM.
Old 11-19-2013, 08:31 PM
Color: Cool Vanilla
Thank you! The reason I am asking, I am trying to solve a passenger side headlight problem. I works part time. When I start out in the morning the headlight could be out, both high and low beam, part way to work the light will come on. I had read that it could a corroded contact, but since the headlights are not routed through an FCM I guess I will have to look elsewhere. I guess it will be back to the dealer. With 92,000 on my 2010, it will be on my dime. Thank you again.
Old 11-19-2013, 08:42 PM
Vehicle: .
Rep:4373
I have read in some posts that the connector and wire to the harness has been know to have issues, I could not find the post again, its somewhere in here in the lighting section. Something to do with the connection of the bulb or somewhere down the wire from the bulb socket to the main harness. Hope that helps. Keep us posted on what you find.
Old 01-20-2014, 11:23 AM
Color: Cool Vanilla
I finally got the light problem fixed. It was the headlight wiring harness that pigtails high beam and low beam together. The Dodge dealer I take my truck to said there were no tech sheets covering that problem, but I insisted they change the harness because of what I have read here. I have read about people having this same problem with their 2010 Rams all over the internet. The part is called a Headlamp Jump Harness Part #68193062AA. This is a very frustrating problem, and I hope this helps someone.
