Dash rattle? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Old 11-19-2013, 07:38 PM
dodgeboy360's Avatar
Vehicle: 2015 Dodge Ram
Color: Granite
Rep:505
Default Dash rattle?
I'm kinda hoping this is a common issue so someone can tell me what it is... I was driving home from work today first time I heard it and I was following a truck with ladders on the roof so I was assuming it wa the truck. The truck turns and it still there... Sounds like it's coming from the cowl area of the driver side. Maybe behind dash, or could be under the hood. But it's just a light rattle like something is loose. Anyone got any idea?
Jordan
2015 Ram 1500 crew cab 4x4 Hemi
Trailer tow package, timbrens, husky liners, k&n drop in, roll up cover, 14" magnaflow w/4" stainless tip, LED bedlights, led reverse pods, 2" HBS, Bfg KO2
Old 11-20-2013, 04:00 AM
KA1OTE's Avatar
KA1OTE KA1OTE is offline
Ram Ham
Vehicle: 2012 Ram 1500 Laramie CC
Trim Level: Millennium Falcon
Color: Mineral Gray Metallic
Rep:1503
KA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant futureKA1OTE has a brilliant future
Check out this thread:
http://www.ramforumz.com/showthread....indshield+clip
That should get you started on narrowing in on that annoying rattle.. Best of luck to ya!
Old 11-20-2013, 09:06 AM
Asur Asur is offline
Vehicle: .
Rep:4373
I read at one time, not sue if it was here, that it was here that behind the glove box somewhere near the center of the dash there is a bolt with a washer, and the bolt is not tight, the washer rattles and makes just a little noise, if you have bad hearing you wont hear it, but if you got good hearing it will send you through the roof. Anyways, something to look at if your under there, seems you can access it by removing the 2 glove boxes. If I find the post I will PM you the link.
