Old 11-20-2013, 12:56 PM
BlueRam1500's Avatar
BlueRam1500 BlueRam1500 is offline
Vehicle: 2009 Dodge Ram
Color: Blue
BlueRam1500 is on a distinguished road
Cool Remote Start
So it's getting cold and I was going to go ahead and install a remote start on my 2009 Ram 1500...the parts guy at the dealer is telling me that they don't make one for my truck?!?! Has anyone installed a factory one on their truck? I have considered going aftermarket but don't want to deal with another key fob...that and I an concerned about voiding electrical using an aftermarket kit...
Recon Projector HIDs/K&N air filter/interior LED lights/ Truxedo Tonneau Cover/RinoLiner Pro the bed and bumpers/Smoked the Tail & brake lights/Smoked the Grill
Old 11-20-2013, 01:45 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:1945
brandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant future
I know for sure you can get an OEM remote start for a 11-12 truck. I'm not sure with an 09 would be any different. You're looking at about $200 for the kit online. Then you could install it yourself if you feel comfortable with that and have the dealer add the sales code after. Otherwise you will have to get them to fully install it which will obviously cost more money.
Otherwise look at the DB-ALL kit. It's much cheaper and uses your factory fob. You just press the lock button 3 times and it starts the truck. It won't be as integrated into the truck as the OEM system is though.
Sponsored by:
8" BDS Long Arm Lift with Fox 2.0 Shocks | Dual Fox 2.0 Steering Stabilizer | 37x13.5 Toyo MT's | AMP Powersteps & Bedstep | Bakflip G2
EST 500 hp/1268 ft-lbs at FW | H&S MiniMaxx Custom Tuned | 4" Flo Pro Stainless TBE | Sinister EGR Delete | ARP 425 Head Studs | S&B Intake w/ Scoop
Old 11-22-2013, 02:49 PM
MBR MBR is offline
Vehicle: 2010 Ram 1500 Sport
Rep:66
MBR will become famous soon enough
http://www.leeparts.com/dodge_ram_ds...rt_system.html
Old 11-23-2013, 06:07 PM
eltoro2's Avatar
eltoro2 eltoro2 is offline
Vehicle: 2oo9 standard cab 4~4 1500 ram
Trim Level: plain
Color: pearl black
eltoro2 is on a distinguished road
have fatory one in mine works like a charm , take it to another dealer . love it !
Old 11-23-2013, 06:14 PM
Asur Asur is offline
Vehicle: .
Rep:4362
Yup, what Brandon said, check out Xpresskits DB-All, 80$, plug and play and uses your FOB, no need for another FOB,. and you can install in like 15min
Old 11-25-2013, 01:50 PM
Color: Blue
Thanks guys! I will check out these options and see what works for my needs...I like the idea of being able to install myself and it be plug and play! I contacted a guy here in town and he said that he can install an autopage system that can be programed using my OEM remote, but it 300 bucks...didn't really want to spend that much...that and I was not sure how much splicing and dicing he would be doing to my wiring...I will let you know...
Old 11-25-2013, 09:41 PM
Rogerwa's Avatar
Rogerwa Rogerwa is offline
Vehicle: 2009 Dodge Ram 1500 5.7l Crew
Color: Greystone
Rep:30
Rogerwa is on a distinguished road
AS said before, the DB-all kit cost me less than $70 and took me less than 10 minutues to install. With the specialized harness, its a no-brainer.
2009 Ram 1500 Big Horn Crew Cab 5.7l Hemi
Twin Cities, MN
Old 11-29-2013, 09:45 PM
upstech76 upstech76 is offline
Vehicle: 2009 Dodge Ram Quad Cab
upstech76 is on a distinguished road
I just had a relative install a factory kit in my '09 dodge 1500. He did tell me they quit making the system for the '09 models but was able to find old stock at another dealer and had it shipped in. The install itself took about 45 minutes to complete and the parts cost $275 his cost. So I would suspect to pay several hundred more to get a dealer installed system unless you know someone.
Old 12-03-2013, 08:08 PM
BCFD8x1o's Avatar
BCFD8x1o BCFD8x1o is offline
Vehicle: 2009 Ram 2500
Trim Level: Larime
BCFD8x1o is on a distinguished road
Will this DBALL kit work on the Diesel? Is it simply download, plug in and turn the key? If it is as easy as it looks to install, I'll buy the flash module as well as the harness and do it myself for almost nothing.
Old 12-10-2013, 11:55 AM
chrisnarron chrisnarron is offline
Vehicle: 2009 dodge ram 1500
Color: gray
Rep:59
chrisnarron will become famous soon enough
Yes it ill work on your diesel. If you buy it from doug on ebay he can program your runtime for however long you want. He can also program it to have a crank delay so the the truck will tirn on and let your gliwplugs warm up then crank. I installed mine in 10 mins and love it.
remote start question
