Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Dodge Ram Aftermarket Brakes
Dodge Ram Aftermarket Brakes Aftermarket Big Brake Kits. Not for discussion of General Brake Maintenance.
Place your Ad Here!
Old 11-21-2013, 02:26 PM
HOOAHHemi's Avatar
HOOAHHemi HOOAHHemi is offline
Vehicle: 2006 Dodge Ram 1500
HOOAHHemi is on a distinguished road
Default Powerstop fitment issue
I ordered a powerstop brake kit for my 2006 Ram 1500 4x4 from Summit racing. I just tried to put the front brakes on, new rotors and pads, but much to my dismay I found that the new pads and rotors won't fit in the stock brake caliper. I have changed my brake pads before but this is the first time for the rotors. I seems that it is only 5mm off at most. Should I have the new rotors shaved down? I'm clueless as to where to go from here and would rather save $350+ doing the install myself then taking it somewhere and letting them figure it out. You gear heads have never let me down before!!
6'' BDS Suspension w/ Fox 2.0 rear shocks, Bilstein 5100 adjustable front struts, 17'' XD Addict wheels, 37x12.5R17 Mickey Thompson Deegan 38s, Diablosport inTune, K&N 77 Series intake, Flowmaster 10 Series SIDO, Mag-Hytec diff cover, Rumble Bee hood, one piece aluminum grill, Extang Trifecta.
Old 11-21-2013, 02:43 PM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1125
Something doesn't smell right. Don't machine off any material from your rotors. You shouldn't have to. Did you push back the caliper pistons as far as you can?
285/65/20 BFG TA KO2s, Bilstein 5100s, Solid Fold tonneau, Rhino Liner, Husky Weatherbeaters, Magnaflow 18 muffler, Mufflex 5" tips, Carbon wrapped interior trim, Chime delete, Britax baby seat...
Old 11-21-2013, 06:08 PM
HOOAHHemi's Avatar
I'll have to give it another go and see if maybe I wasn't doing something right. I pushed the calipers back as far as they would go, or so I am thinking I did. I'm at work now, it'll have to wait until Saturday. I checked and double checked my order against the part numbers on powerstop's website and it's the same kit numbers. Thanks for the response and hopefully I get it figured out.
Old 11-21-2013, 07:05 PM
LowUFO's Avatar
Rep:1125
No worries. My guess is the pistons aren't pushed back far enough.
Old 11-27-2013, 11:41 AM
jcon44's Avatar
jcon44 jcon44 is offline
I NEED TO UPDATE MY EMAIL ADDRESS!!!!
Vehicle: 2005 Ram 1500
jcon44 is on a distinguished road
I installed the same set on my 05 and they fit fine. i used c-clamps on the pistons.
Old 11-29-2013, 11:50 PM
HOOAHHemi's Avatar
I haven't had the time between work and family and Thanksgiving but as soon as I get a minute, I'll check it out again. I'll let you guys know how it goes.
Old 12-17-2013, 03:38 PM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:368
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
so is this fix now?
i would also tough the piston are not completly push back
i usualy put one of the old pad against the piston and use a big chanel lock pliers or a big c-clamp to compress it when i dont have the proper piston tool,.. maybe you can try that
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover, powerstop brake kit.
Old 12-17-2013, 04:07 PM
Rep:2910
That is what the mechanic did with my brake job
he took the old brake pad & placed it against the caliper pistons & used a C clamp to compress them
Old 12-17-2013, 04:50 PM
crusher's Avatar
Rep:368
yes it works like a charm,. almost better than with the real piston compression tool imo
Old 12-27-2013, 07:13 PM
HOOAHHemi's Avatar
I'll try both of those techniques. It's been a crazy month and I just haven't had the time to stop and install the new set. I can't wait until the holidays are over.
