Old 11-21-2013, 08:30 PM
jaray jaray is offline
Trim Level: Sport Crew
Rep:197
jaray has a spectacular aura aboutjaray has a spectacular aura about
Default Park sense sensor error (cold)
Washed my truck tonight after our first cold night with below freezing temps and I get an error saying "rear ParkSense unavailable wipe rear sensors"
Obviously the water probably iced up on the sensors but I got out and checked and they're perfectly clean and dry. No ice whatsoever. I've looked on their surface and there is no ice.
Been through 2 key cycles and no change. I certainly hope these aren't going to become a problem in the winter.
Anyone else seeing this in freezing temps?
Gibson Cat-back exhaust w/black tips, S&B CAI, MGP caliper covers, Recon LED 3rd brake light, Bilstein 5100's, Daystar 1" rear coil spacers, Weathertech floor liners, Westin Ultimate series bull bar, Dee Zee Tailgate Assist, Mopar T- Handle, Kicker speaker upgrade
Old 11-21-2013, 09:01 PM
Rep:197
Well the error seems to have cleared itself after awhile but backing up went complete red and beep as if there was something right behind when there wasn't. Went out and ran my fingers across each sensor and tried again - all normal.
So who knows what went on there but I hope these sensors aren't going to be troublesome in the winter. They've surely been out long enough now that they should be all figured out.
I'm sure salt and snow will definitely block them but this little issue was way too sensitive.
Old 11-21-2013, 09:31 PM
lbram81's Avatar
lbram81 lbram81 is offline
Vehicle: 2013
Rep:99
lbram81 will become famous soon enough
Had this same issue on my 07 grand Cherokee. Almost every time they would get wet that message would pop up. Dealership couldn't figure it out. One of the reasons I'm glad I own a express without all that electrical non sense.
Real question is: Does Ram Quality Control Personnel really exist???
Old 11-21-2013, 11:00 PM
smurfs's Avatar
smurfs smurfs is offline
Rep:105
smurfs will become famous soon enoughsmurfs will become famous soon enough
Have this same issue, funny thing was- after it dipped down to about minus 25, they came back to life. Go figure. I just shut them off now, but the annoying part is the big warning on my EVIC every time I put it in gear. I am going to see if the service department has a way to just shut them off completely and remove the warnings.
Old 11-21-2013, 11:09 PM
dustin72's Avatar
dustin72 dustin72 is offline
Vehicle: 2013 Dodge Ram1500 4x4
Rep:48
dustin72 is on a distinguished road
Mine do the exact same thing.
Black SRT10 22's with 305/45/22 Nitto NT420S Tires, 6000k Low and Fog HID's, Debadged, Tint, Custom Mopar Badges, S&B Intake, Magnaflow Muffler, Superchips Tuner
Old 11-21-2013, 11:56 PM
J Roc's Avatar
J Roc J Roc is offline
Vehicle: 2013 Ram 1500 Sport Crew Cab
Rep:29
J Roc is on a distinguished road
Get used to turning them off for the winter.
Old 11-23-2013, 11:39 AM
tev9999 tev9999 is offline
Trim Level: Outdoorsman
Color: Maximum Steel
Rep:39
tev9999 is on a distinguished road
I ran into the same thing after the temperature dropped below 30 last week. I went to back out of my driveway and it alarmed with the closest bars as soon as I went to reverse. I assumed it was iced up and didn't bother checking. At my next stop I checked and saw they were clear, but wiped them anyway. Later I cycled the system off then back on and the right side cleared. Later that day it was working fine again once the temp warmed up. I also had one day (warm weather) when the system decided to turn itself off as I was stopping at a red light.
Back in the 20s again this week so I will see how it goes. Just another little glitch to get the dealer to take care of when something big is needed.
Old 05-12-2014, 02:37 PM
DHanna DHanna is offline
Vehicle: 2014 Ram 1500 Sport
DHanna is on a distinguished road
jaray,
Do you have front park sensors as well? Does your bull bar interfere with the sensors at all?
I'm looking at the same bar (Westin Ultimate) but want to make sure it will fit without having to deactivate the parking sensors.
Thanks,
