'13 Sport 6 speed question - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Old 04-29-2013, 01:32 AM
Backlash Backlash is offline
Vehicle: 2013 Dodge Ram
Trim Level: Sport Crew Cab
Rep:27
Backlash is on a distinguished road
Default '13 Sport 6 speed question
Ok, so I traded my 09 Big Horn(5.7) in for a '13 Sport CC(5.7) with the 6 speed trans. My question is that it doesn't seem to matter what speed I'm at and just maintaining that speed (i.e. 30, 40, 50 m.p.h.) even on city/surface streets, the engine/trans seems to fall into a gear that is too high for the speed I'm going. Kinda like a manual transmission would do if you were going 20 m.p.h. and shifted into 5th gear and stepped on the gas. It also seems like when this happens and I step on the gas, the pedal goes down a good 1-2 inches before I get any response and even then it seems to "bog" down a bit before it takes off. Is this normal for the 6 speed? I hope not...if it is, I think I'll be sorry that I got rid of my Big Horn. It never did that and when I stepped on the gas in that, it took off like a scared rabbit!
Old 04-29-2013, 02:04 AM
eldorado99 eldorado99 is offline
Vehicle: 2012 RAM
eldorado99 is on a distinguished road
MY '12 Outdoorsman did that for the first 3-5K miles. It disappeared around there and seems basically normal now at 13K miles. It is a bit of a sluggish transmission though...
Old 04-29-2013, 08:42 AM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2009 SLT MegaCab
Rep:165
Otterdriver has a spectacular aura aboutOtterdriver has a spectacular aura about
Pretty easy to overcome, I have the same transmission, just bump your shifter to manually limit your top gear for in town. Depending how tall your gears are will help you decide. There are times I limit mine to 4th, sometimes 5th, works very well.
http://i1132.photobucket.com/albums/...62f9145c5d.jpg
STEALTH DELETES/ BUSHWACKER FLARES/ AMERICAN RACING RIMS/ EFI LIVE 75 HP TOWING TUNE/ OD TUNE
Old 04-29-2013, 09:26 AM
rraulston rraulston is offline
Vehicle: 2013 Ram Sport Crew Cab Hemi
Rep:7
rraulston is an unknown quantity at this point
I have no issues. same truck as you. It runs high gear to save gas. try running in tow/haul mode. you may like the shifting schedule better....
Old 04-29-2013, 09:29 AM
RAM SPORT CREW's Avatar
RAM SPORT CREW RAM SPORT CREW is offline
Vehicle: 2012 Ram Sport Crew
Rep:110
RAM SPORT CREW will become famous soon enoughRAM SPORT CREW will become famous soon enough
It's the dammed Eco cylinder deactivation mode, I hate it and drive in 4 or 5 all the time. The only time I leave it in D is on the highway and Eco mode doesn't bother me at all in this scenario. Tranny will also learn your driving style and adjust accordingly, which is what I think was the case in a previous posters response.
Old 04-29-2013, 11:34 AM
Rep:7
its my understanding tow/haul mode will deactivate the MDS....
Old 04-29-2013, 09:04 PM
Rep:27
Seems odd to me that Dodge would make a transmission that does that and give it the "ok". Shouldn't have to put it in "tow/haul" or manually set the gears to keep it from doing something it really shouldn't do. I've never experienced anything like that in any vehcle I've ever been in unless, like I said in my original post, it was a manual trans and you were in too high of a gear for the speed you were going
Old 04-29-2013, 09:14 PM
Ronan's Avatar
Ronan Ronan is offline
Vehicle: 2013 ram sport crew
Trim Level: Sport crew
Rep:42
Ronan is on a distinguished road
Vararam and an 87mm TB work good for me, now I don't have to punch it to downshift. Also leave it in 6 around town and it won't use MDS. Any gear really, but if you don't want to bother shifting leave it in sixth. I prefer 4th around town. TETO
ARH long tubes and y pipe,Vararam CAI, Moes 87mm, flowmaster, Edge 3000 stall,180 t-stat , e-fan swap, Ati 15% U/D pulley, Ebc rotors and pads, Diablo trinity w/ hemifever 93tune, 22" R/T's , bilsteins set at 2.1...for now ,lost the 35's, slimming down....
Proud member of LOCAL 361 IRONWORKERS
Old 04-29-2013, 10:07 PM
RyanJM's Avatar
RyanJM RyanJM is offline
Trim Level: Express RC
Color: Black Express Package
Rep:67
I leave mine in 5 around town and 6 on the highway. I actually have tested it and I get better mpg's keeping the mds off. Can't wait for a tuner to shut it off. Wish it was an option on these trucks so I could have had it turned off when I got it.
Old 05-06-2014, 04:13 PM
HammerHead's Avatar
HammerHead HammerHead is offline
Vehicle: Ram 1500
Rep:20
HammerHead is on a distinguished road
YEP me too. I got the 6 speed and on the low end its sucks. Sometimes when I hit the gas it bogs down and sometimes it takes off it depends what speed I'm at. Very frustrating to honest. But from 60-110 its balls out fast
Geared-Tuned 0-60 in 4.82
Proud member of the 4 second club...
