tonneaucovered.com
Old 10-23-2013, 12:38 PM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:368
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
Default help,..rear diffentiel clutch ??
my truck is in today for the rear diff recall (their rebuilting a good part of it), and they just called me to let me know that my clutch were all wear out and needed to be replace right away,.
they also say normally it's not cover under the recall but they manage to make it go on it,.. so free of charge
so i have 2 questions for thoses than know 's about differentiel
1- can the fact that my nut was looses and cause the parts to move inside my rear differentiel be the cause of the clutch braking
2- what normally whode be the cause of the diffentiel clutch to worn out, to be no more good?
thank'S
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover
Old 11-14-2013, 11:10 AM
Swaggerville Ram's Avatar
Swaggerville Ram Swaggerville Ram is offline
Vehicle: 2009 Ram 1500
Color: Deepwater Blue
Rep:130
Swaggerville Ram will become famous soon enoughSwaggerville Ram will become famous soon enough
thank'S
The loose nut would not be directly causing the excessive wear on the LS clutches, however if your diff was leaking out the pinion seal, I could see how that would wear them out.
The short answer to the wear is heat.
How it saw the excess heat could be a few different reasons, but if it lost fluid that is what I would blame.
"I don't care to hear what your ideas are, mine are better"
Old 11-14-2013, 12:26 PM
Asur Asur is offline
Vehicle: .
Rep:4373
thank'S
1- No, would not affect the clutches
2- On Anti-Spin Diffs eventually the clutches wear out and require replacement. The harder you use the LSD (more burnouts, etc.) the shorter the life of the clutches.
Old 11-14-2013, 12:56 PM
TJC.geotech TJC.geotech is offline
Vehicle: 2014 Ram 1500 Crew
Color: Granite
Rep:114
TJC.geotech will become famous soon enoughTJC.geotech will become famous soon enough
2. one or two extended one wheel spins will take them out.
Old 11-20-2013, 08:00 AM
crusher's Avatar
Rep:368
thank's for the reply's
