Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Old 11-22-2013, 08:59 PM
keyloki keyloki is offline
Vehicle: 2013 3500 cab chassis
Rep:49
keyloki is on a distinguished road
Default Tech seeking VSIM answers
Hi all,
I'm a truck equipment tech that is turning an 06/2013 3500 Diesel Auto cab chassis into an aerial truck for a municipal utility company. Rather than a PTO, this has a clutch pump. The end user requires remote start/stop AND 2 remote throttle advances. From what I understand, I cannot use the factory "PTO" switch without loosing the remote start/stop. Since this is a clutch pump, I don't care about what switch is used. My problem is that after a remote stop event, if the engine is remote started, I loose the VSIM for throttle advance. I assume this is because there was no actual ignition cycle. If I give the truck a physical key cycle, the VSIM is reset an my throttle advance is back. Does anyone know how to get the VSIM to reset after a remote Start event short of physically turning the key off and back on?
TIA (and I REALLY mean that !!!!)
Old 11-22-2013, 09:42 PM
Asur Asur is offline
Vehicle: .
Rep:4373
The only way I see is to setup a reset on pin 28, the pk/yl wire to the VSIM module, from what i can see it would reset the +12v to the unit even if the truck is running, but this ends up being the same as putting the key back to off and then on so I am not sure you can actually setup a reset to that from a remote, Sorry I don't think you will be able to do it.
Old 11-22-2013, 09:57 PM
Rep:49
is the pk/yl wire an input? could I maybe use a timer relay to send it a +12 signal after X amount of seconds? effectively creating a "reset"?
Old 11-22-2013, 11:07 PM
Vehicle: .
Rep:4373
here take a look at this, it might help in how you could use a reset to the module.
http://www.rambodybuilder.com/2013/docs/ram/ramvsim.pdf
Old 11-23-2013, 12:07 AM
Rep:49
Thanx a ton but I already have this info. I know I can "trick" this VSIM system into doing what I want....I just hafta figure out how. I joined this forum in the hopes that someone else had figured it out already. When I figure it out and make it work the way I want.... I will be sure and post a " how to" on this forum.
