Old 11-24-2013, 02:59 PM
Hemi13's Avatar
Hemi13 Hemi13 is offline
Vehicle: 2013 Ram Laramie
Rep:89
Hemi13 will become famous soon enough
Default 4wd auto vs 4wd lock wear and tear
We just got our first dump of snow here in Newmarket and I had some fun with the truck. When the roads are partially snow covered would be best to use 4wd auto? Is there risk to any parts if the front drive is automatically being engaged on and off a lot as roads get slipperier? In this condition, is it better to just engage 4wd lock so that the front drive stays engaged-will this reduce wear on the linkages etc? In cases where you just need 4wd 100% it's a no brainer.
I'm sure there will be different views on this. I'm just looking to hear some logic either way.
On another note the stock 20" tires passed the test. They don't compare to any snow tires I have owned but as long as I braked early and didn't try to turn quick I was ok.
2013 Laramie, Hemi, 6spd, 3.55, silver, push button/keyless start, sunroof, nav etc
Old 11-24-2013, 05:10 PM
Monster5601 Monster5601 is offline
Vehicle: 2013 RAM 1500 Laramie
Color: Cherry Red
Rep:470
Monster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of light
Yes.
When you go to 4 wheel lock, you are locking in the gears for the front axle. You should only use this mode on slippy surfaces and off road. As you can imagine, the gearing between the front and rear isn't perfect and if the front wheels are not allowed to slip on occasion, you would create a bind and add stress to the drive-line.
4 auto mode only engages the front axles (this is what the owners' manual indicates), gearing is engaged as needed based on detected slippage.
Old 11-24-2013, 05:21 PM
Asur Asur is offline
Vehicle: .
Rep:4373
From the Manual
4WD AUTO mode, the front axle is engaged, but
the vehicle’s power is sent to the rear wheels. Four-wheel
drive will be automatically engaged when the vehicle
senses a loss of traction. Because the front axle is engaged,
this mode will result in lower fuel economy than
the 2WD mode. When additional traction is required, the transfer case
4WD LOCK and 4WD LOW positions can be used to lock
the front and rear drive shafts together forcing the front
and rear wheels to rotate at the same speed. The 4WD LOCK and 4WD
LOW positions are designed for loose, slippery road
surfaces only. Driving in the 4WD LOCK and 4WD LOW
positions on dry hard surfaced roads may cause increased
tire wear and damage to the drive line components.
4wd Auto can be run on any surface at any speed.
For variable driving conditions, the 4WD AUTO mode
can be used. In this mode, the front axle is engaged, but
the front and rear driveshafts together forcing the front
and rear wheels to rotate at the same speed. This is
accomplished by rotating the 4WD Control Switch to the
desired position. Refer to “Shifting Procedure” for specific
shifting instructions. The 4WD LOCK and 4WD
tire wear and damage to the driveline components.
Old 11-24-2013, 07:09 PM
Swaggerville Ram's Avatar
Swaggerville Ram Swaggerville Ram is offline
Vehicle: 2009 Ram 1500
Color: Deepwater Blue
Rep:130
Swaggerville Ram will become famous soon enoughSwaggerville Ram will become famous soon enough
I personally do not like the auto option. I know quite a few GM guys that had to rebuild tcases because of this. I don't know if the ram setup is better or not but I'd be willing to bet it is similar. Too easy for it to engage under hard acceleration, it will only do that so many times till it breaks
"I don't care to hear what your ideas are, mine are better"
Old 11-24-2013, 07:12 PM
benefactr benefactr is offline
Vehicle: 2011 Dodge Ram Quad
Color: Deep Water blue
Rep:50
benefactr will become famous soon enough
I love the 4WD auto, will not get another truck without it. Also works great when the roads are wet from the rain.
Old 11-24-2013, 08:09 PM
Rep:130
4 lock works just fine too
Old 11-24-2013, 09:46 PM
Hemi13's Avatar
Rep:89
Thanks for the details.
From the Manual
Old 11-24-2013, 09:52 PM
Hemi13's Avatar
Rep:89
That's the reason for my concern, I love the functionality of auto 4wd. Anyone have issues running it a lot through a few winters?
Old 11-25-2013, 08:02 AM
Vehicle: .
Rep:4373
Had it on my Jeep grand cherokee 2001, still working today, when I got the truck the first day the Mechanic ( a friend) came out and showed me how to engage and disengage all the different 4x4 possibilities on the truck, I always shifted it as prescribed, the truck is still on the road today and Zero Issues with the transfer case. I am not saying that these are the same units, what I am saying is if done correctly you will probably not have any issues with it. The truck does have a 5 year 100k mile drive train warranty, I don't think that one major parts in the truck should be a week point and because it was used. Over the years I have talked to many that have had issues with there's only to find out that they were the reason that there 4x4 would screw up, usually due to misuse. Most never even read the manual on how to use them, they just figure its above them. JMO
Old 11-25-2013, 08:18 AM
edge35's Avatar
edge35 edge35 is offline
Trim Level: Laramie Longhorn 4x4
Rep:70
edge35 will become famous soon enough
I'd be very surprised if using 4wd Auto caused any appreciable accelerated wear. Using 4WD lock on any surface that has anything above mediocre traction (including wet pavement) is likely to do much more damage.
2013 Laramie Longhorn 4x4
6 speed (although the 65RFE is really a 5 speed), 3.55, air suspension, anti-spin, 20" Goodyear Wrangler SRA tires (aka crap), sunroof, Bakflip Fibermax & BakBox, bed extender, 8.4AN, black/cattle tan interior
