Old 11-25-2013, 03:12 PM
thkbaron thkbaron is offline
Vehicle: 2011 ram sport crew 4x4
Rep:61
thkbaron will become famous soon enough
Default Bushwacker Pocket Flares Running 295's
I haven't been able to find the answer yet so this is my attempt. Is anyone out there running bushwacker pocket flares with a 295 wide tire? If so do you have pictures or can you tell me how even the tire is with the outside? Obviously it depends on what offset you are running. I would like to run a 34 inch tire hence the 295. I would like the tire to sit a close to even with the outside as possible. The wheels I want would have a -12 offset. Thanks.
2011 Ram Sport 4x4 Crew Cab
Old 11-25-2013, 03:26 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
I'm assuming a 9" wide wheel with a -12 offset? If so you'll be tucked under the flare at least 1". Probably closer to 1.25". Hopefully someone will have pictures of what that looks like for you.
Old 11-25-2013, 04:41 PM
Rep:61
yeah that's no good. might have to go with a set of oem flares then.
Old 11-25-2013, 04:56 PM
Rep:2026
You'd be way better off with a set of OEM flares IMO. It will look much better with that set up. Take a look at getting the 2500/3500 flares. They don't come down quite so far on the front which gives them a more aggressive look.
Old 11-25-2013, 08:44 PM
Rep:61
Yeah if you check out this link you'll see why I was thinking the bushwacker pocket flares:
http://www.nolimitbmore.com/work/dod...ith-xd-wheels/
Old 11-26-2013, 12:15 AM
Rep:2026
Ahh yes. I remember seeing the thread where you posted that. It definitely is a sick looking set up. I would definitely run the larger tire to make it look right though.
Old 11-26-2013, 02:36 AM
Bigred74's Avatar
Bigred74 Bigred74 is offline
Vehicle: 1999 Dodge Ram 1500
Rep:258
Bigred74 is a jewel in the roughBigred74 is a jewel in the roughBigred74 is a jewel in the rough
dont know if this will help you or not but here is my 2nd gen with bushwackers with a 285 tire... didnt really like the look of the pocket flares on small tires so i took them off. im running 315's now so just need to spray them in bedliner and then put them back on to see how i like them. heres some pics:
now 315's but no fender flares yet
how far they stick out: (also running a 9in rim with -12 offset)
hope that helps ya
*Bedliner paint job, leveling kit, 3'' body lift, 17'' eagle alloy rims series 197, 315/70/17 Nitto Trail Grappler M/T tires, S&B cold air intake, 52mm ported and bored throttle body, Superchips 3865 programmer
Old 11-29-2013, 09:23 PM
Rep:61
assuming my truck has a similar width that helps a lot actually! thanks!
Old 12-02-2013, 02:48 AM
Bigred74's Avatar
Rep:258
np man post up some pics once you decide what your goin with
Old 12-02-2013, 10:00 AM
SteelTownStang's Avatar
SteelTownStang SteelTownStang is offline
Rep:262
SteelTownStang is a jewel in the roughSteelTownStang is a jewel in the roughSteelTownStang is a jewel in the rough
Nice looking truck in the link...
MODS: Magnaflow Cat-Back Exhaust, aFe Stage II CAI, Extang Solid-Fold Tonneau, Mopar Side Steps, Mopar Mats & Bedliner, AMP Bed XTender, Daystar 2.5 Leveling Kit, Fuel Pump Black Wheels (20x9/+1 Offset), Toyo Open Country Extreme A/T Tires (35/12.50/20), Aries Stealth Bull Bar, & KC SlimLites.
