Old 02-15-2014, 10:34 AM
dinows dinows is offline
Vehicle: 2002 dodge ram
Color: gray
dinows is on a distinguished road
Default Blower Runs But No Air Comes Out
Bought a 2002 1500 and the blower runs in all 3 positions and selection switch works, But only a "TINY" bit of air comes out. I am freezing, can someone help ?
Thanks Much, Deano
Old 02-15-2014, 12:00 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
maybe the blend door actuator?
Old 02-22-2014, 09:26 PM
AFMEDIC's Avatar
AFMEDIC AFMEDIC is offline
Vehicle: 2002 Dodge Ram
Color: Maroon
Rep:18
AFMEDIC is on a distinguished road
blend door controls hot or cold, that may be a problem, but I don't think so on your truck. Is the fan speed appropriate for which setting it is on (high, med, low)? You will have to judge it by sound since you aren't getting the flow. If the fan doesn't blow at high medium and low speeds, it would point to an electrical problem (blower motor resistor, but usually when these fail you get only high speed, no low or medium). If the fan speeds are appropriate, you may have a mode door problem. The mode door selects which duct work the air blows through (defrost/floor, face, face/floor, floor etc.) If there is something wrong with the door or the actuator, the air will not be flowing 100% where you select and you will get the "weak" flow because you are losing air to other vents.
Check out these videos and they may help:
Heater Treater Diagnostic and repair videos, part 1,2,and 3
http://www.youtube.com/watch?feature...&v=KAclL84Qq8E
http://www.youtube.com/watch?feature...&v=XRo1ook3v9I
http://www.youtube.com/watch?feature...&v=Hu0BIvhDT8E
If Guns kill people, then pencils misspell words and spoons made Rosie O'Donnell fat...
Old 03-08-2014, 05:55 PM
jonny68 jonny68 is offline
Vehicle: 2002 dodge ram 1500 slt
Color: red
jonny68 is on a distinguished road
hey i had the same problem it was the blend door located behind the glove box I cut the plastic screened and removed it becuase it was broken. Havent replaced it yet but heat works fine. Good luck.
Old 03-09-2014, 05:21 PM
Color: gray
Default blower runs but no air comes out
Hi when you cut behind the glove box, was this a big job ? not sure I understand what you did
Thanks Deano
