Old 11-27-2013, 10:16 PM
Bcera's Avatar
Bcera Bcera is offline
Vehicle: 2010 Dodge Ram Quad Cab SLT
Bcera is on a distinguished road
Default Anyway to get Traction Control to cut completely off instead of half off with the button?!
This half off traction control nonsense has to go. Traction control button should be on and off not on and almost off. If I wanna drift around in my truck then I should be able to with out it deciding im taking it to far.
Bushwacker Pocket Flares - Diablo Intune i1000 - Magnaflow DODS18 - Bilstein 5100s - BakFlip G2
Old 11-28-2013, 09:32 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:418
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
If you get a Diablo Predator you can probably turn it off. I find that at least in my Dodge Magnum, the Predator tuner already reduces the sensitivity a lot, maybe too much. Also when you have almost 400 hp and you turn off traction control, things can get out of control pretty fast. My 05 don't have traction control, in snow and ice you'd better be on your toes.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 11-28-2013, 09:36 PM
mmateri mmateri is offline
Vehicle: 2013 ram
Trim Level: sxt
Rep:30
mmateri is on a distinguished road
i would love a solution to this also, my truck is no fun in the winter
Old 11-28-2013, 10:45 PM
Bcera's Avatar
I've grown up with European rear wheel drive sports cars so the rear end sliding is what I'm after and this TC only let's me do that to a point.
Old 12-02-2013, 10:21 PM
rockdoc's Avatar
rockdoc rockdoc is offline
Vehicle: 2010 Dodge Laramie Hemi
Color: Grey with silver trim
rockdoc is on a distinguished road
I'm not 100% positive but.... If you hold the traction control button in for 10 seconds you will see the warning lights for anti-lock etc light up in the dash and a chime, I believe, this is telling you it has been disabled. I do see a difference but am not positive this is, in fact, happening. A service tech told me about this. Anyone else try this?.
Old 12-02-2013, 10:45 PM
Bcera's Avatar
That would be dope. I'll try tomorrow
Old 12-02-2013, 11:32 PM
grizzlylongcut grizzlylongcut is offline
Vehicle: 2011 ram sport
grizzlylongcut is on a distinguished road
i dont think you can, with out a programmer. know if your in 4 wheel drive you can hold down the button and wait for it to go off,which is usefull in some situations
Old 12-03-2013, 12:24 AM
Ram306 Ram306 is offline
Ram306 is on a distinguished road
The only way I have noticed to get traction control to turn completely off is when you are in 4wd and you hold the button down for about ten seconds then full traction control is disabled
Old 12-03-2013, 12:37 PM
Boosted's Avatar
Boosted Boosted is offline
Trim Level: Outdoorsman
Color: Black/Mineral Gray
Rep:219
On my 2011 Wrangler, the traction control worked exactly like on the Rams, however there was a sequence of key on, turn steering wheel one way and then the other, key off blah blah blah that would completely shut off traction control. I'll try to find how I did it and try it on the Ram. You would think they worked the same.
Old 12-03-2013, 01:31 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I believe you can push the button and pull the ABS fuse and that disables it 100%
Sean
