Catch Can Install for Pentastar 3.6L V6 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Old 11-30-2013, 03:52 PM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Default Catch Can Install for Pentastar 3.6L V6
When I removed my engine cover, I found a small puddle of oil at the Throttle Body, oil in the engine cover and in the PCV line. I had only 2000 miles on the truck and none of them were hard driven miles. (no WOT)
I ordered and installed a Billet Technology Catch Can on my 2013 Pentastar 3.6L V6 Engine. I found very little information on installing a Catch Can for the Pentastar Engine.
No one makes a Catch Can Kit for a Ram truck with the Pentastar V6 engine, so I went and ordered a Catch Can Kit from BT. Part # (Billet Technology Signature Series Catch Can 2011 and up Jeep 5.7L, Jeep 6.4L and Durango 5.7L)
The kit comes with 1 Catch Can and mounting bracket, 2 hoses 1/2", 1 double male brass hose connector 1/2" with barbed ends, and 2 screws.
I had to purchase (1) 1/2" brass 90` fitting and (2) 1/2" brass male hose connectors with barbed ends. These 3 parts make up a 90` hose fitting and were purchased at Home Depot.
I mounted the Catch Can on the side of the TIPM wiring box using one existing hole and drilling one additional hole. I used 5/16" hardware.
I removed the PCV hose from the engine cover and cut off 6". Next I inserted the supplied 1/2" double male barbed connector into the outlet end of the PCV hose (one you just cut) coming from the back of the engine. Next attach the supplied 1/2" hose to the connector and run it to the inlet side of the Catch Can.
Next assemble the 3 brass parts to make up the 90` fitting and take the other end of the cut hose (cut down so the brass barbed end just fits) and insert into the barbed fitting. Connect the supplied hose to the 90` fitting and to the outlet side of the Catch Can. Connect the other end to the inlet on the engine cover.
I took 17 pictures and I have them in order of progression with captions. See the pictures here: http://s1331.photobucket.com/user/gc...?sort=6&page=1
Total cost was about $150
Any questions just ask.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 12-01-2013, 11:11 PM
arietem's Avatar
arietem arietem is offline
Vehicle: 2013 Dodge Ram 1500 4x4 QCab
Trim Level: SLT - 8spd 3.55 20"
Color: Mineral Gray Metallic Clear
Rep:368
arietem is just really nicearietem is just really nicearietem is just really nicearietem is just really nice
Reps for the photos .. guess this is next on my list !
Nice job!
Regards
Old 12-06-2013, 09:43 PM
rrgmrg rrgmrg is offline
Vehicle: 2014 Ram 1500 4x4 Crew Cab
Trim Level: Bighorn
Rep:104
rrgmrg will become famous soon enoughrrgmrg will become famous soon enough
Thanks for the step by step, my next project.
Randy
Old 12-07-2013, 10:36 AM
Asur Asur is offline
Vehicle: .
Rep:4373
Very nice write up, sweet, reps to you bro for a great install
