Improving factory Alpine sound? - Page 7 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-24-2014, 06:56 PM
JoeFro JoeFro is offline
Vehicle: 2014 Ram 1500
Color: Deep Cherry Red
JoeFro is on a distinguished road
tac40 is correct. The kicker sub goes under the drivers side rear seat whereas the factory amp is under the passenger side rear seat. I have a 2014 Laramie CC with the 8.4a radio alpine.
@tac40: The instructions were confusing on the wires to splice into on the harness to the factory amp under under the drivers side dash. There were two wires of one color - I think it was the gray wire with the brown stripe. I chose the one that was right next to the other wire that I was supposed to splice into. They were both in the middle of the harness whereas the other option was at the end. I gambled. If that is the question that you have I could verify that is what I did.
I went to install the infinity's in the dash tonight and I bought the wrong wiring harness. I bought the Metra 72-6514 which was mentioned in this thread. That one did not fit my truck - the plug is too big. I need to find out the right one. I have a 2014, so don't know if there was a change across model years.
Joe F
Old 03-24-2014, 07:31 PM
tac40's Avatar
tac40 tac40 is offline
Senior Supporting Member
Vehicle: 2013 Ram 1500 2WD CC
Trim Level: SLT Lonestar
tac40 is on a distinguished road
Joe F
Hi @JoeFro,
Yep..... that was why I called Kicker tech support earlier. My black 16-pin connector on the Alpine amp had 14 installed pins, and according to the instructions, we splice into the "gray wire with a brown stripe" and the "green wire with a brown stripe". Trouble is, my connector has two of each and when I tested, each like-pair did not tone out. The gentleman that I spoke with at Kicker said that it did not matter which pair I chose. So.... I chose the two closest to the end. (Opposite of what you did). I did some other checks and as far as I can tell at the moment, everything else looks good so I was about to contact them again. Am tempted to hold off a few hours and try splicing to the other pair. This time I'll take pictures of the connector and where the spliced wires are connected.
--mike
Old 03-24-2014, 07:37 PM
tac40's Avatar
Joe F
I had the same problem with my initial purchase of the Metra 72-6514. The plug was too big. I had to get Metra 71-039. Am pretty sure that's what you need. Check out my related posts in this other thread: http://ramforumz.com/showthread.php?t=163546&page=2
--mike
Old 03-24-2014, 08:11 PM
Thanks Mike - that is really helpful. Wish I would have seen that other thread... Looks like I need to order some 71-039's. Good luck on your sub. Your going to love it. Totally transforms the system.
Joe
Old 03-24-2014, 10:03 PM
Yo Nadz Yo Nadz is offline
Vehicle: 2013 Ram 1500 Sport Crew Cab
Trim Level: Sport Crew Cab
Color: Snow White
Rep:160
Yo Nadz has a spectacular aura aboutYo Nadz has a spectacular aura about
I'm with JoeFro. Spliced the wires in the middle of the harness and everything works fine.
I also ordered the wrong speaker harnesses and had to get the 039s. Only place I could find them was crutchfield.
Yo Nadz STOMPER Build Thread ~> http://www.ramforumz.com/showthread.php?t=135821
Lifted & Ignorant 2013 Sport Crew
Proud member of IAFF LOCAL 2665
Old 03-25-2014, 08:14 AM
tac40's Avatar
Default Getting closer - Found Amp connector pinouts
Just found Alpine amp pin-outs for the 16-pin black connector (posted on another forum). It doesn't show the duplicate color-code pairing so I suspect that it's from an earlier year/model though.
left to right / top to bottom
pin 1 gray with purple stripe (LH front door -)
pin 2 gray with yellow stripe (LH front door +)
pin 3 green with purple stripe (RH front door -)
pin 4 green with yellow stripe (RH front door +)
pin 5 green with brown stripe (sub +) <<-- Connect green wire w/black stripe (Kicker harness "negative") here
pin 6 gray with brown stripe (sub -) <<-- Connect solid green wire (Kicker harness "positive") here
pin 7 gray with dark green stripe (LH rear door +)
pin 8 gray with light green stripe (LH rear door -)
pin 9 green with yellow stripe (RH rear door -)
pin 10 green with gray stripe (RH rear door +)
pin 11 gray with no stripe (center dash speaker)
pin 12 gray with orange stripe (center dash speaker)
pin 13 yellow with gray stripe (RH headliner +)
pin 14 green with no stripe (RH headliner -)
pin 15 not used
pin 16 not used
If the above pin-outs are correct, this raises another question. Why would the Kicker harness sub + (pos) connect to the amp connector sub - (neg), and vice-versa? Any ideas? Thanks!
--mike
Old 03-25-2014, 09:21 AM
DAA DAA is offline
Vehicle: 2013 1500, CC/6'4", Hemi/8 spd
Trim Level: Longhorn
Rep:352
DAA is just really niceDAA is just really niceDAA is just really niceDAA is just really nice
Thanks for clarifying the Kicker install position.
And yes - it's the 71-039 you need for the dash speakers. That's what I used in my '13 anyway.
The doors use Crutchfield #1207150.
- DAA
Old 03-25-2014, 11:51 AM
tac40's Avatar
Default That was it! Use Pin5(+) and Pin6(-)
I also ordered the wrong speaker harnesses and had to get the 039s. Only place I could find them was crutchfield.[/QUOTE]
Ok, now I'm a happy camper. I moved the input-signal splices to pins 5 & 6 near the middle of the connecter and BAM! Everything works great now. Thanks for the help, @JoeFro & @Yo Nadz! :-)
--mike
Old 03-25-2014, 12:05 PM
DRam14 DRam14 is offline
Vehicle: 2014 Dodge Ram 1500 4x4
DRam14 is on a distinguished road
- DAA
I used the 13's 71-039 on my 14's stock dash speaker system, and it didn't fit. The plastic connector fit to the stock one, but the female connectors on the ends would not fit to the speaker. They were too small, so i had to cut them off and splice on some new female connectors.
Old 03-26-2014, 08:45 AM
DAA DAA is offline
Rep:352
It's the factory plug that you buy the harness for though and it sounds like that did fit your '14. Spades are generic as it gets.
But I got my 71-309 harness adapters from Crutchfield and the spades did fit on the Infinity 3032's. Very tight fit, had to open them slightly with a small screw driver blade and use pliers to seat them, but that's not a bad thing.
- DAA
