Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 12-01-2013, 10:31 AM
Cameo Cameo is offline
Vehicle: 1999 Dodge Ram 2500
Cameo is on a distinguished road
Exclamation Engine runs cold. No heat
Sorry to be posting ANOTHER heater problem, but couldn't find a post with my same symptoms.
Bought a 99 Ram 2500 5.9 little over a year ago to haul my horse trailer. No problems with heat last winter, darn near ran me out of the truck!! Temp gauge has always run @ 210, summer & winter.
Drove 45mi to work the other night, (20 deg outside) Drove 30 mi before I could hold the wheel w/o gloves on, never did really warm up. Temp gauge about 170. Lukewarm air out of vents. Called hubby told him I needed a thermostat.
Next am (10 deg) Checked radiator, topped off with VERY small amt of antifreeze, added some to reservoir. Noted small amt of scum on inside of rad. cap. also with truck running it didn't look like the fluid was circulating.
Put a LARGE piece of cardboard in front of radiator, no help whatsoever.
OK, he change thermostat but it didn't help. Next we changed water pump, flushed the system, back flushed the heater core, filled with new antifreeze. still doesn't look like it's circulating. Still runs cold, 56 deg. out & cardboard still in place. No heat.
Someone posted somewhere it could be a head gasket. Would that make an engine run cold?? I just checked the oil & it looks fine.
BTW about a month ago I was hauling home when my check engine light came on. I first thought it was bad gas. I normally gas up at the same station. The next time I drove to town I stopped at a National parts chain to use their scan tool. It didn't pull up any codes, figure it was a bum scanner but haven't tried another. ANY suggestions? Please?
Thanks in advance.
Old 12-01-2013, 03:17 PM
slimpartywagon's Avatar
slimpartywagon slimpartywagon is offline
Vehicle: 1995 Dodge Ram 1500, 2000 Ram
Trim Level: Laramie, SLT
Color: Blue
Rep:95
slimpartywagon will become famous soon enough
Yes it could... I had the same thing happen on my Jeep Wrangler. On a nother vehicle, it was a pin hole leak in the heater hose.
Old 12-06-2013, 07:32 AM
Thumbs up Got Heat now
Picked up a thermostat at the dealer. Engine now comes up to temp. Guess I didn't need the water pump. That's ok, at least it wasn't the heater core!
Old 01-06-2014, 07:33 PM
lildh4573 lildh4573 is offline
Vehicle: 2001 Dodge ram
Trim Level: SLT Laramie
Color: Blue/Silver
lildh4573 is on a distinguished road
Default you helped me
Thank you for that last comment I am currently on my 2nd thermostat from the same part store and my truck is still not hitting temp so now I will b going to the dealer to get my next one
Old 01-11-2014, 12:40 AM
Lazarus Truck Lazarus Truck is offline
Vehicle: 1997 Dodge Ram
Rep:194
Lazarus Truck has a spectacular aura aboutLazarus Truck has a spectacular aura about
X2 with Cameo. The t-stat you buy at the discount "Chinesium" store is alot different than a real part from the dealer. Most of us grew up trusting Stant and Bosch. You CAN'T trust anyone anymore as far as T-STATS! My last t-stat from Mopar from another motor actually weighed 2 ounces more than the replacement!
The difference between genius and stupidity, is that genius has it's limits. A. Einstein
