Old 12-01-2013, 01:24 PM
sealeytwin sealeytwin is offline
Vehicle: 2003 dodge ram 1500 hemi
Color: atlantic blue
sealeytwin is on a distinguished road
Default Has anyone had THIS power window problem?
I seen similar problems on here but nothing quite like mine. Ok first off i have a reg. cab so there is no window lock switch. The passenger window goes up and down real slow with the passenger door switch but it works fine with the passenger window switch on the driver panel. Here is the weird thing, when i press the passenger door switch up or down the blower motor comes on. Anyone had this problem?
Old 12-01-2013, 08:23 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
I had an old Jeep Grand Cherokee that had something like that happen, it was the wiring harness that comes into the door from the cab. Those wires get flexed a million times, eventually, $hit happens. Still the blower coming on, don't sound like that would be it.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 12-02-2013, 12:55 PM
Simple guy Simple guy is offline
Vehicle: 2003 Ram 1500
Trim Level: SLT QC 4x4
Color: Mineral grey
Rep:109
Simple guy will become famous soon enoughSimple guy will become famous soon enough
There is a harness connector maybe two at the right passenger kick panel. I assume that would be a good place to start. Not sure exactly what all is in that connector but I know I had to disconnect it to remove my hvac box to do a heater core. it's a short to pwr between the window circuit and the blower. It can be anywhere alone those two circuits. Does the window operate normal speed if the blower is already on?
Old 12-02-2013, 07:10 PM
No, when the blower is ON the window goes even slower, sometimes it doesn't work at all.
Old 12-24-2013, 04:47 PM
Default found problem
It was a broken wire.
