Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion > Nitrous Discussion
Nitrous Discussion Questions and Answers regarding adding Nitrous Oxide to your Dodge Ram.
Old 12-01-2013, 07:34 PM
TBILLIOT's Avatar
TBILLIOT TBILLIOT is offline
Vehicle: 2011 dodge ram 1500 quad cab
Trim Level: sport 4x4
Color: hunter green pearl
TBILLIOT is on a distinguished road
Default Spark plugs?
I plan on running a 100-125 shot what plugs fo i need?i know i have to go 2 degrees colder but im not sure which ones are..so if u have any part numbers that would be great
Old 12-01-2013, 07:47 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
I believe the best plugs for nitrous are the Brisk ones. Do a Google or Yahoo search. I just run 1 range colder champion copper or 1 range colder ngk copper and gap to .35. You can run them year round, spray or not. I just went to NAPA auto parts and gave them the stock plug number and they ordered the colder plugs for me. I've used both ngk and champion, somewhat surprised, but the champions seem to last even better than ngk's. Hell, I've got over 80,000 mi on the copper champions in my RT Magnum, still runs great. Only spray a wet shot, at wot above 2,800/3,000 rpms. I have a hot button and an arming switch handy to my right thumb, let off the nitrous after you go thru the quarter mile traps then let off the gas. If you install a 2800 rpm converter, you might be able to hit the button as you launch, and "Holy $hit"
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 12-01-2013, 07:51 PM
I push the skinny pedal
Rep:3277
The Brisk plugs were the best shrouded plug for the pre-'09 heads, but with the tapered seat of the Eagle heads you want something like the Denso 3381. They're a projected tip, but they are fine with spray. Ideally you use a shrouded tip, but with a 'small' shot like a 125 you're fine, over 200 and you can start cooking the ground strap in short order.
Kurtis
Old 12-01-2013, 07:57 PM
TBILLIOT's Avatar
I have 3,000 stall in the truck now and about to put 4:10's front and back with dr's all the way around
Old 12-03-2013, 04:37 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
Ngk 4306 what I used
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
