Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 12-02-2013, 11:38 AM
jakem49's Avatar
jakem49 jakem49 is offline
Vehicle: 1999 dodge ram 4x4
Color: red
jakem49 is on a distinguished road
Default 16x10s?
im running a 99 4x4 single cab with a 2 inch leveling kit on brand new 315/75/16 cooper discover st's they only scrub a little bit when i have the wheel fully turned, this is with the stock wheels. im going to get new wheels because the stock ones are too skinny and the tires arent wearing right. my question is will 16x10's with 4 inch backspacing cause it to scrub worse? or will that improve my scrubing? thanks for any info
if you cant dodge it, RAM IT!!!!!
Old 12-02-2013, 12:58 PM
Wh1t3nukle's Avatar
Wh1t3nukle Wh1t3nukle is offline
Vehicle: 2000 Ram ORE 4x4 5.9L
Trim Level: Laramie SLT
Rep:57
Wh1t3nukle will become famous soon enough
It will scrub worse. May even require fender trimming.
Why do you think the stock wheels are too skinny? Is this change for looks? How do you use your truck? What is the target for your reasoning of that wheel size?
I'd suggest not going any wider than 9" on the wheel and no less than 4.5" for backspacing.
00 Ram 1-ton ORE; 3" BL; 14" coilovers; ARBs, 37" Toyos; R/T Camshaft; Mopar M1; Custom long arms, sliders and bumpers; 12K Winch; York +5g OBA
Old 12-02-2013, 01:24 PM
jakem49's Avatar
Color: red
I think they're too skinny because the outside of the tires aren't wearing only the inside is I use it for a daily driver and very mild offroading (driving to the deer stand and back) I wanted that size to make it sit higher and I want the wheels to improve wear on the tires and a little better look! Thanks for the feedback!
