ZDOG
Old 12-02-2013, 09:21 PM
SteelTownStang's Avatar
SteelTownStang SteelTownStang is offline
Rep:262
SteelTownStang is a jewel in the roughSteelTownStang is a jewel in the roughSteelTownStang is a jewel in the rough
Default TPMS with New Wheels & Tires
Hello,
I'm planning to purchase a new tire/wheel set-up. Are the OEM TPMS connected by straps, or are they the valve stem type on the 2014s?
Also, I've read that the '14s are different than the '13. If I were to purchase the set-up for one of the big on-line tire retailers with the TPMS installed will they work or should I buy them separately? Will I need a sequencing tool?
Lastly, I've also read that you can deactivate the TPMS on the '14... due to running snow tires. Is this true as I cannot find this information in the manual?
Thanks!
MODS: Magnaflow Cat-Back Exhaust, Extang Solid-Fold Tonneau, Mopar Side Steps, Mopar Mats & Bedliner, AMP Bed XTender, Daystar 2.5 Leveling Kit, Fuel Pump Black Wheels (20x9/+1 Offset), Toyo Open Country Extreme A/T Tires (35/12.50/20), Lund Fender Flares, Aries Stealth Bull Bar, & KC SlimLites.
Old 12-02-2013, 09:40 PM
DarthRam's Avatar
DarthRam DarthRam is offline
Join the Dark Ram Side!
Rep:1543
The TPMS are the valve type. The 14s use a different frequency than the 13s. If you buy them with your tires from a tire place they should supply the correct ones. I would call them ahead of time to make sure they can get the correct ones in for when you buy the new tires. They will automatically sync with your vehicle after a few miles. If you take them off for snow tires/wheels the truck should stop warning you they are not working (Or missing) after 25 miles or so. It slips in to Winter tire mode automatically.
Old 12-02-2013, 10:07 PM
Rep:262
Thanks for the information. I was also thinking about just powder coating the OEM wheels black. Do you know if you can remove and reinstall the OEM sensors?
Old 12-02-2013, 10:34 PM
RC51 RC51 is offline
Vehicle: 2016 Laramie Limited
Trim Level: Laramie Limited edit
Rep:58
RC51 will become famous soon enough
The 2014 sensors run on same frequency as 2013 but 2013 sensors don't work on 2014. Tpms sensors direct told me they work on some different protocols 2014 vs 2013. When I ordered my 2014 snow tire/wheel package at Discount Tire Direct they put OEM sensors from Dodge dealership on my order. Their system identifies the wrong sensors on my order but I emailed their customer service right away after they emailed my order confirmation. They fixed it before sending my order out. The cost of oem sensors from 2014 are cheaper than 2013 oem.
Old 12-03-2013, 12:51 AM
DarthRam's Avatar
Rep:1543
They are removable but when you start taking them off and on you run the risk of breakage. For as much as all that tire juggling is going to cost I would just get a set off eBay.
Old 12-03-2013, 12:52 AM
DarthRam's Avatar
Rep:1543
I stand corrected. They are different part numbers from Ram.
Old 12-03-2013, 08:39 PM
Rep:262
Thanks... Do you have a part number... and cost for the '14 sensors?
Old 12-03-2013, 09:09 PM
DarthRam's Avatar
Rep:1543
Here you go:
http://www.factorymoparparts.com/68157568aa.html
Old 12-03-2013, 09:43 PM
Rep:58
The 2014 tpms aremuch cheaper than 2013 TPMS. I think I googled some 2014 sensors from a Dodge dealer in USA at $29 piece plus shipping. In Canada I could get them from my dealer for $49 but 2013 were $80 plus I think.
The good is there cheaper in 2014 but the bad is the 2013 don't work with the 2014.
Old 12-04-2013, 06:12 PM
Flatlandor Flatlandor is offline
Vehicle: 2014 Dodge Ram 4x4 Quad Cab
Color: Deep Cherry
Rep:531
Flatlandor is a glorious beacon of lightFlatlandor is a glorious beacon of lightFlatlandor is a glorious beacon of lightFlatlandor is a glorious beacon of lightFlatlandor is a glorious beacon of lightFlatlandor is a glorious beacon of light
I was able to take the sensors off my 2014 stock wheels and put them on my aftermarket wheels with no issues. Everything works fine.
2014 Laramie QC 4x4, tan interior, 3.92's, sport hood, customized Moto Metal wheels & AT tires, LineX bed, rockers and fender flares, K&N Filter, cabin filter, "black ice" grill inserts, Putco bed rails, RollBac tonneau cover, LED bed lights, Mufflex 14" with Mufflex resonator and stock resonators, Moroso catch can and a "matching" 2008 special edition "Will Cooksey" Z06 - #139 of 505.
