Old 12-03-2013, 01:43 PM
beerboobsbacon's Avatar
beerboobsbacon beerboobsbacon is offline
Vehicle: 2001 dodge ram 1500
Trim Level: laramie
Color: white & black two tone
beerboobsbacon is on a distinguished road
Exclamation HELP! choosing cam, lifters, intake manifold etc.
Well i just joined today and was looking for some help unleashing some horespower out of my 318. I was looking for anyone's experience/expertise on which cam and lifters i should run and anything else that would get me around 350 hp for $1000 to $1500. part numbers or links would be appreciated!!
my truck is a 2001 dodge ram 1500 with 4.88 gears on 37's its currently in the shop getting Detroit lockers front and rear. with all this time without my baby i have been looking into doing some engine work.
1500 4x4 quadcab 10" lift 3" body 37" mtrs on pro comps 4.88s locked
Old 12-03-2013, 04:50 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
The problem that you have is, to pull big power out of a 318, you'll have to build it to rev like hell. Then you have to give up bottom end grunt that you need to move a heavy truck.I would think the only way you'd get 350 hp would be with forced induction. You'd probably need better rods and pistons just to handle the power of a blower. I'm guessing a stock 318 has about 230 flywheel hp. With forged internals to handle a blower, maybe 6-8 lbs of boost headers and a good blower cam, ported heads, you probably could get 350 flywheel hp if you could get it tuned. Way out of budget. Don't take it the wrong way, but if you could find an 04- newer hemi, well they come with 345 hp and 390 ft/lbs stock. Also, hemi trucks come with the 545RFE 5 speed good for 500-550 rwhp without upgrade. I run a hot cam in my hemi, headers, custom dyno tune and probably only gained 40-50 more rwhp. With my hot cam, my bottom end is no better than stock, have to rev to get the power. Probably will raise my shift points to 6,500.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 215,000 miles To Hell and back. 14.2/96 mph NEDW
Old 12-03-2013, 05:18 PM
Trim Level: laramie
so if i had the heads ported, put in a cam, lifters, rockers etc did a big gulp throttle body, air gap intake and headers, and a tune, what kind of numbers would i be looking at?
Old 12-04-2013, 02:21 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
The Magnum factory heads support 400hp at 6,000rpm. Any work there will be a plus that will make it easier to hit your goal. Improved induction (M1 or Hughes/Edelbrock AIr Gap) and higher cfm throttle body will dovetail nicely with that rpm range. A hot computer-friendly cam is in order. I'd suggest calling the cam manufacturers or at least doing the online cam request form. To hit 350hp or anywhere near that at around 5,500rpm you're gonna need a pretty stout cam like CompCams 264HR-12. Don't forget the matching springs. Add a good exhaust and you'll have the major areas covered. On the carb'd 400hp 318, it would crank 349 lbs torque at 3,000rpm, so it doesn't give up low rpm power like most smallblocks do. 9 years ago Hot Rod did an article called "Junkyard Jewel: 400hp 318". It was a buildup of the LA 318. Your Magnum already has big port heads (the LA had small ports). It's a good read that offers insight into just what the 318 can do. Even though there are some considerations that must be dealt with in the computerized applications, you can still crank it out. Check out the dyno numbers. There was also a Magnum head conversion where the Magnum-ized 318 cranked out almost identical numbers.
http://www.hotrod.com/howto/113_0304...d/viewall.html
Also a Magnum head conversion, but higher flow Mags and more cam.
http://www.popularhotrodding.com/tec...e/viewall.html
Old 12-04-2013, 08:28 AM
Trim Level: laramie
thanks Gen1dak! Much needed info! So this is possible! woooo! now i was thinking last night of going down the path of a turbo setup or pro charger...anyone done this or have any insight ??? if so what are you running(or would run)?
Old 12-04-2013, 11:51 PM
Rep:85
On the stocker, you'll be limited to about 9psi. That'd still net at least a 40% power increase. More boost would demand forged pistons and a stronger head gasket setup, stronger crank and rod bolts.
Old 12-05-2013, 08:36 AM
Trim Level: laramie
Soo what are people running for turbos on the 318 ? Could I set one up with the same budget? 40% increase sounds good to me, I will prob still add an air gap manifold and a 52+mm throttle body working with the turbo setup . Do I have to change anything else besides just installing the turbo intercooler controller etc.?
Old 12-05-2013, 09:12 AM
MOP4RN4TION's Avatar
MOP4RN4TION MOP4RN4TION is offline
Vehicle: 1996 Ram 1500
Trim Level: 1500
Rep:387
MOP4RN4TION is just really niceMOP4RN4TION is just really niceMOP4RN4TION is just really niceMOP4RN4TION is just really nice
tuner, and maybe injectors. Upgrading your ignition system might not hurt either. I know MSD makes plug and play setups specifically for Turbo or Forced Induction. The exhaust will need looked at too. More Air/Fuel volume in requires more volume out. A marginal catalytic will quickly clog up and crap out if you over tax it with a turbo. Depending on the mileage of the motor, it may need to have rings/bearings refreshed as well.
The 40% increase would assume all the internals are in good working order. Throwing a turbo on a dogged out powerplant with 300k miles on it wouldn't see that 40%, and if it did, it wouldn't see it for long.
Two things are infinite: the universe and human stupidity...― Albert Einstein
Old 12-05-2013, 03:01 PM
Trim Level: laramie
So I would need a custom tune and injectors? Any idea how many pound injectors would be adequate for my application? On the other hand the exhaust is already takin care of I did a cat delete straight pipe to an open magniflow no restrictions.also the engine was recently swapped in the truck and gone through it has 93k of grandma driven miles runs strong!
Old 12-05-2013, 03:41 PM
Trim Level: 1500
Rep:387
Injectors would depend on what you have and what the turbo units requirements are.... The tune is going to be necessary without question
