Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 12-03-2013, 08:43 PM
tscoc tscoc is offline
Vehicle: 1997 Dodge Ram
Color: Green
tscoc is on a distinguished road
Default Installing 5" Lift Kit
Hi. I'm looking to lift my '97 Dodge Ram with a 5" kit. It has an Automatic tranny with 318 motor and it is 4x4. Can someone enlighten me as to the "RAMifications" of doing this such as; level of difficulty, modifications to current vehicle parts. I just want to be sure I have my bases covered before I attempt this project!!! Thanks, Tom
Old 12-04-2013, 05:16 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
It shouldn't be that difficult. For the front, you'll just need to replace the springs, control arms, trac bar, and possibly a drop pitman arm. If you need to change the pitman arm, you'll want a puller for that.
For the rear, you'll need either bigger lift blocks, or springs, depending on the kit.
I might have missed something, but these front ends are pretty simple. What kit are you going with?
Old 12-05-2013, 08:19 PM
Color: Green
Just curious what difference it would be from one kit to another?
Old 12-14-2013, 07:11 PM
Color: Green
Rough country 5 inch lift.
Old 01-21-2014, 07:13 PM
nicraage nicraage is offline
Vehicle: 2001 Ram 1500 4x4, 5.2L
Color: Flat Black
nicraage is on a distinguished road
I put a 5 inch rough country on my 2001 a while back. It comes with the drop pitman arm, and blocks for the rear. Everything was included except for the steering stabelizers which need to be replaced. I went with skyjacker dual steering stabelizers.
They look like they have different shocks than they had when I bought mine. Mine have a pretty rough ride.
Old 01-21-2014, 08:36 PM
Color: Green
I'm using the 5" Rough Country kit on my '97 Ram 1500 4x4. I'm just a little skeptical about what issues I may run into since this is a first. Also, I have to wait till better weather to accomplish this project.
Old 01-21-2014, 08:41 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Engine: 2014-20?? 182ci (3.0L) L630DOHC V6 240hp 420lb/ft Eco-Diesel
Rep:2471
Shoot Andrew at Bully's a PM, he's the forum expert on lifts and can source everything you need.
sales@revelperformance.com
Old 03-07-2014, 07:32 PM
Howells's Avatar
Howells Howells is offline
Vehicle: 1999 dodge ram sport 5.9l
Trim Level: sport 4x4
Rep:19
Howells is on a distinguished road
Pretty simple install. I would rec having new control arm bolts at hand as they will break or have to be cut off. I had to replace the cam bolts and one upper bolt.
