Old 12-18-2013, 07:38 PM
Minnwild1 Minnwild1 is offline
Vehicle: 2011 Ram
Trim Level: Outdoorsman
Color: GRN
Minnwild1 is on a distinguished road
Default Ram will not start. TIPMA?????
I have a 2011 Outdoorsman with factory remote start and 48,000 miles. Hit the remote starter 2 days ago and nothing happened. I figured maybe my fob battery is weak, so I grabbed the other one and tried that. Nothing.
Went out to the truck and hit the unlock button on both fobs and nothing... Pulled the key out of the fob and opened the door. The alarm went off. Dash said remote start diabled and insert key. i inserted the key and tried to turn it on. Nothing happened. the key is now stuck in the ignition.... Try to gently persuade the key out, but no go. Temp is -18 F and I was getting frustrated. 6 Am and the neighbors are most likely ready to kill me as the horn is beeping and all lights flashing. It stopped after 5 minutes. I needed to get the service contract and info out of the glove box, so had to go back in. Alarm went off again. Tried to get the key out, but no go.
Called the dealership and they said that I must have put my key too close to one of the demagnetising things at the store... I said that I tried both keys. They replied that if the truck goes into safe mode, that it doesn't matter. Late for work and cold. Called Dodge because I have the lifetime bumper to bumper warranty through them. They sent a flatbed to come and pick it up. The overage (miles to dealership) cost me $50. Service contract picked up $100.
Dealership had the truck for 2 days. They said that they positively diagnosed and fixed the problem. It says on my service invoice that they found that, "the TIPMA had a update for no start and alarm passive". The corrective action says, "completed new update vehicle works fine now". They also did the pinion nut recall. They charged me $165.15. I asked if it was covered under my warranty, and they said that no, it is not covered because my truck has more than 36,000 miles on it.
The remote starter worked this morning just fine. Drove to work and noticed that when I let off the gas, the truck seems to drag or decelerate much more quickly than before. After work, i hit the remote start and nothing happened. Tried it again and the alarm went off. Horn blaring and lights flashing... WTF. I disconected the battery for a few minutes, got in and started it and drove home with no problems. Anyone have an idea of what i should do? Called dealership and they said they could get me in on the 30th. I'm starting to wonder if i should go look for a different truck.
Old 12-18-2013, 07:39 PM
Vehicle: 2011 Ram
Color: GRN
I did a search in here to try to find someone having similar issues, but can't seem to find anyone. What would be a good keyword to search? Alarm system?
Old 12-18-2013, 11:43 PM
Color: green
Rep:643
is that the dealer you bought the truck from
Old 12-19-2013, 01:36 AM
Vehicle: 2011 Ram
Color: GRN
Mt first call was to the dealership where I bought the truck. It is ~45 miles away. I took it to the closest dealership which is where the Dodge service contract people set up the appointment.
Old 12-19-2013, 06:19 AM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Uh, if you have the lifetime bumper to bumper warranty, why does the warranty not work after 36K? Either you're mistaken or the dealership just pulled a fast one on you.
Old 12-20-2013, 12:40 AM
Vehicle: 2011 Ram
Color: GRN
They said that the update is not covered under the extended bumper to bumper warranty. Seems to me if Dodge programmed something wrong and made a fix for it that it should be offered free, like a recall thing.
Old 12-20-2013, 03:43 AM
God Bless Texas!
Rep:2929
I call bull shit!
