Horn mods - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 12-18-2013, 12:32 PM
Medrano95's Avatar
Medrano95 Medrano95 is offline
Vehicle: 2011 Dodge Ram
Medrano95 is on a distinguished road
Default Horn mods
I am looking to change or at least add a horn to my truck. I had the classic dixie(dukes of hazard) horn in mind. Any thoughts on kits or issues/shortcuts?
Old 12-18-2013, 12:35 PM
Asur Asur is offline
Vehicle: .
Rep:4373
This is what i did, sounds like a diesel train now.
http://www.ramforumz.com/showpost.ph...postcount=1127
http://www.ramforumz.com/showpost.ph...postcount=1144
Old 12-18-2013, 02:22 PM
Brad Pitt's Avatar
Brad Pitt Brad Pitt is offline
Vehicle: 2013 RAM 1500
Rep:93
Brad Pitt will become famous soon enough
That's great, Asur. Nice work!
Old 12-18-2013, 02:29 PM
Vehicle: .
Rep:4373
Originally Posted by Brad Pitt View Post
I like that, Asur. Is it an easy install?
easy, just get a standard wire harness with relay and plug it up on the battery, the instuctions show how to do it and are pretty clear, the trigger is tapped on one of the (+) wires of the OEM horns, you could unplug the OEM horns, but I left them functional. You could also tap into the fuse box if you want also. Easy setup, the instructions say to plug them direct but I checked and you need to plug them off the battery, the OEM horns are only 10amp and these larger horns need 20. Hope it helps.
Old 12-18-2013, 02:32 PM
Brad Pitt's Avatar
Rep:93
Thanks for the quick reply. I didn't view your first link when I made my post, only looked at the video… it looks a bit out of my skill level with the electrical part.
