Old 12-06-2013, 02:12 AM
bartlett bartlett is offline
Vehicle: 2013 Ram quad
Color: gray
Rep:323
bartlett is a jewel in the roughbartlett is a jewel in the roughbartlett is a jewel in the roughbartlett is a jewel in the rough
Default slow to shift into 4+4
anyone have this issue ? My 2013 shifts butt slow. I switch into 4+4 and the light flashes for like 15-30 seconds. I had to sit and wait for it.
I was climbing my driveway after a 8" snowfall and my truck didnt want to go up it. so I stopped and switched to 4+4 waited like 2 seconds and gave it some gas,,,,,,Nope ....waited a few more seconds,,,,nope ,,,,,shifted to N then to D ,,,nope ,,,,reverse to D ...ok then she went in ... This electric transfercase stuff is for the birds.... not a fan ...I wish I would have got a manual shift. I can see getting stranded with a truck that wont shift.
Old 12-06-2013, 04:21 AM
Monster5601 Monster5601 is offline
Vehicle: 13 Laramie 1500, 15 Longhorn
Color: Cherry Red
Rep:470
Monster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of light
You didn't say what transfer case you have nor does your profile list your trim level. When the light is flashing the transfer case is attempting to make the requested change but the conditions required to make the change have not been met.
The owners' manual details the conditions and what else to do if the shift did not happen for each transfer case version. I think if you read through this section (section 5, FOUR-WHEEL DRIVE) to understand the conditions, it will eliminate your frustration.
As far as anyone else have these issues, I've not seen any chatter.
Old 12-06-2013, 04:44 AM
Tribute2Troops Tribute2Troops is offline
Vehicle: 2013 Ram
Tribute2Troops is on a distinguished road
Thought I was alone with the slow shifting transfer case. My 97 Yukon is faster. I haven't check out the owners manual either. So....
Old 12-06-2013, 05:03 AM
Color: gray
Rep:323
mines the tradesman , 4+4 lock . Ive owned 4+4 my entire life. conditions met are Im sitting stuck in 2wd and need 4wd ! lol ..
Old 12-06-2013, 08:19 AM
Asur Asur is offline
Vehicle: .
Rep:4373
4WD Lock is not the same as 4WD Auto, Because there is a physical lock in the transfer case and the truck is not moving sometimes, the wheels have different weight pushing on them or the incline of the hill, it cannot easily lock the 2 drive lines together, best way when standing still is to just put the truck in natural and let the truck move a tiny bit by slowly letting off the brake, this is usually all that is needed for it to transition to the 4WD Lock position. If by doing this in these particular times does not help then check in with your dealer, just see if it can be reproduced easily or they will just say its normal.
Old 12-06-2013, 09:43 AM
chuck2417 chuck2417 is offline
Vehicle: 2013 Ram 1500 Quad Cab Sport
Rep:158
chuck2417 has a spectacular aura aboutchuck2417 has a spectacular aura about
4x4 Lock does take a bit longer. To make it go quicker I find turn off traction control, put transmission into neutral and you should be stopped. I haven't tried letting off the brake. the 4x4 Auto takes 3-5 seconds maybe from 2wd. I have the 8 speed transmission and mine is controlled by the buttons. 4wd lock takes longer than all the rest, for reasons mentioned above by Asur.
Old 12-06-2013, 02:19 PM
Thunderhorse's Avatar
The Sound of Eight Hooves
Rep:545
Thunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of lightThunderhorse is a glorious beacon of light
I believe it shifts into 4wd easier if you are moving with your foot off the gas.
Thunderhorse-Built: 25 Feb 2013 Warren, Michigan; Bought: 28 May 2013
Huskyliner Weatherbeaters, door edge guards, Line-X bedliner, Kryptek Typhon Cordura seat covers w/ MOLLE panels (review), Console Vault (install/review), Bilstein 4600s (thread), BFG T/A KO2 LT275/60/20s (thread), Borla XR-1 (thread), Matte black Plasti-dipped center console bezel, BT catch can.
