Seat and steering wheel heat keep coming on - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Old 12-06-2013, 08:59 AM
evensen evensen is offline
Vehicle: 2017 Ram 1500
Trim Level: Laramie Crew Cab 4X4
Color: Pearl white
evensen is on a distinguished road
Default Seat and steering wheel heat keep coming on
This started a week ago. Almost every time I get in and start the engine, after about 5 seconds, the driver's seat heat and the steering wheel heat come on.
I am used to just turning them off, but it is annoying.
Old 12-06-2013, 09:03 AM
Bruce E's Avatar
Bruce E Bruce E is offline
Vehicle: 2013 Ram Longhorn Crew Cab
Trim Level: Longhorn
Rep:55
Bruce E will become famous soon enough
I believe it is automatic when the outside temperature dips below a certain temperature. Mine does this as well but I don't mind because it is cold here. I assume there is a way to disable this feature in the EVIC but I haven't looked.
Vararam Cai, ARE Cap, 35" Dick Cepek Mud Country, DC-2 Wheels, Diablo Trinity.
Old 12-06-2013, 09:30 AM
Rusty289's Avatar
Rusty289 Rusty289 is offline
Vehicle: 2014 Ram 1500 Crew Cab
Rep:117
Rusty289 will become famous soon enoughRusty289 will become famous soon enough
Whats the outside temperature when this happens?
It is an option and can be turned off in your settings, I think its called "Auto On Comfort" something like that.
If ya can't Dodge it, Ram it!!!
Old 12-06-2013, 09:35 AM
Bruce E's Avatar
Rep:55
Mine starts coming on when it is 0 celcius (32 F for my southern friends) give or take a few degrees.
Old 12-06-2013, 10:00 AM
Color: Pearl white
I will check in the EVIC settings. Auto on is not mentioned in the downloaded manual. Thanks for the answers.
Old 12-06-2013, 10:03 AM
Ram Dude's Avatar
Ram Dude Ram Dude is offline
Vehicle: 2013 RAM 1500 5.7 SPORT
Rep:27
Ram Dude is on a distinguished road
mine started to do it to when it hit a certain temp, but IDK what the temp had to be......
Old 12-06-2013, 10:48 AM
Sideshow48 Sideshow48 is offline
Vehicle: 2013 Dodge Ram 1500
Color: Copperhead Pearl
Rep:136
Sideshow48 will become famous soon enoughSideshow48 will become famous soon enough
There should be a setting in the EVIC to disable if you so choose...look for something like this...
Auto-On Comfort & Remote Start...
Auto-On Driver Heated/Ventilated Seat & Steering
Wheel With Vehicle Start
When this feature is selected the driver’s heated seat and
heated steering wheel will automatically turn on when
temperatures are below 40 F (4.4 C). When temperatures
are above 80 F (26.7 C) the driver vented seat will
turn on. To make your selection, touch the Auto Heated
Seats soft-key, until a check-mark appears next to setting,
showing that setting has been selected. Touch the back
arrow soft-key to return to the previous menu.
Old 12-06-2013, 11:11 AM
Diller Diller is offline
Diller is on a distinguished road
The heated seats/steering wheel come on when the outside temp is below 40*F. I believe the ventilated seats activate at 80*F
Old 12-06-2013, 02:08 PM
dawoodsman dawoodsman is offline
Vehicle: 2013 Ram 1500 Crew
Trim Level: Outdoorsman
Color: True Blue Peal/Mineral Gray
Rep:92
dawoodsman will become famous soon enough
I think there's two different settings in play here. One is auto on which is a temperature based setting (mine comes on every time the truck is started with key if the temp is below 40 degrees F), the other is whether it comes one when you use the autostart feature (if you have it).
Both can be adjusted.
Remember there are two manuals for Rams--a shorter/limited one they provide with trucks, and a much bigger one they (for some STUPID reason) they do not provide with new trucks. Some dealers might give you both (smart in my mind, it sure cuts down on calls to the dealer to resolve things that can be answered by reading the big manual!). Otherwise you can get one free online or a hard copy by calling ram support.
Old 12-06-2013, 02:55 PM
AirborneSilva AirborneSilva is offline
Vehicle: 2013 Ram Sport
Rep:74
AirborneSilva will become famous soon enough
I was quite pleased when mine came on automatically this morning
2013 Ram Sport
1976 Corvette L82
