dodge ram 1500 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Drive Line
Drive Line Ball Joints - Wheel Bearings - Shocks - Springs - Alignment etc.
Old 12-06-2013, 06:01 PM
railhead69 railhead69 is offline
Vehicle: 2005 dodge ram
railhead69 is on a distinguished road
Default dodge ram 1500
i have a 2005 dodge ram 1500 it has a vibration new tires rear drive shaft rebalanced took front one off it starts around 65 mph any ideas out their
Old 12-08-2013, 11:16 AM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:452
hydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of light
Did it start after the tires? Just because a tire balances on a machine, when you put 2,500-3,000 lbs load on it it could vibrate. I've had tires that had a belt fail and they would drive you nuts. The other thing could be a u-joint going bad.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's, Helwig rear sway bar,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 245,000 miles To Hell and back. 14.2/96 mph NEDW
