Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 12-07-2013, 12:20 PM
Marcelo's Avatar
Marcelo Marcelo is offline
Vehicle: 2005 5.7L HEMI
Trim Level: SLT Quad Cab 4WD
Color: Flame red
Rep:34
Marcelo is on a distinguished road
Default Upper ball joints question
Hi, mates...
My '05 SLT CrewCab 5.7 needs ball joint replacement.
No problem in picking the correct lower ones, they're K7467 and so far I found Moog and Mevotech as options...
My problem comes when searching for the upper ones since I've found that both K7460 and K7448 are stated as compatible... but they look pretty different.
K7460 bolt on axis with body
K7448 bolt seems to be off-axis
Clearly this one will give some offset camber to the wheel Which would be the correct part? I know the best way is to take out the worn ones and see, but I wouldn't like to be without my truck while I search for the parts
Thanks in advance for your help...
Old 12-15-2013, 07:29 AM
RogerRamJet's Avatar
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
I'm pretty sure the offset ball joints are for the HD trucks (2500 and up).
Old 12-22-2013, 07:46 AM
Marcelo's Avatar
Color: Flame red
Rep:34
Thanks, Roger... my '05 RAM is a 2500 HD, that's why I'm still askin', wonderin' and wanderin'
I'm pretty sure both are compatible... but just in case I'll go for the straights
