Old 12-08-2013, 09:10 PM
Asur Asur is offline
Vehicle: .
Rep:4371
Originally Posted by Fast FL View Post
I haven't put the mirror back on yet. I kind of figure I have to bring it by the dealership at this point, so why put it back on.
I am not sure exactly what function the wire serves for the mirror. My mirror has the Assist and the 911 buttons in it, and is self dimming. The overhead lights, rear window, and garage door openers all work - as is.
That's just it - EVERYTHING seems to work with the exception of that one wire.
Maybe it was just a spare 12V+, if you put the mirror back and check if all is still working, you might just need to find another +12 to tap into. Anyways, keep us posted on what you find.
Old 12-08-2013, 09:13 PM
Fast FL Fast FL is offline
Vehicle: 2014 RAM 1500
Rep:38
Fast FL is on a distinguished road
I don't think that it is a spare per se. It is the only line that turns off, when the ignition/accessory is in turned off. That's why I used that line - this way, the power goes out on the radar detector when you turn off the car.
Old 12-09-2013, 01:47 AM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Great in theory. Just gotta watch out for those hot wires touching the ground wires. Or... or... turn the power off so you won't have that problem.
Old 12-09-2013, 10:30 AM
Rep:38
Yeah - I know. Like I said before, this is the 4th one that I have done (1st truck) and I never had an issue.
Can't find a "punch myself in the face" animation on here but that's what I feel like doing. So annoyed that I screwed this up!
Old 12-09-2013, 10:32 AM
Vehicle: .
Rep:4371
OK well if you can run that wire down the pillar driver side to the electrical inlet next to the brake pedal you will see a Large Blue wire and I think its lined red, this wire is (+ 12v) on run only I am presuming its a 30amp, you should be able to use that.
Old 12-09-2013, 10:56 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
EDIT: wire (PINK/ W yellow stripe)
This wire is for the SUNROOF
One thing that you did not mention is Sunroof? This one would not work with the key off.
I would check fuse F35 30 amp. And fuse F66 10 amp.
Wiring diagram I think it will be fuse F66 10 amp. that is blown.
https://techauthorityonlinedemo.extr...ew/classic.htm
SUNROOF/POWER TOP SYSTEM / Connector Details
Diagram
Connection (SP2229)
OK, I would put everything back together at this point as Asur stated.
There is only one fuse box in the Ram.
The only thing I can think of is making sure your front head lighting is working correctly along with the movement of the dimming mirror.
If you find that everything works (all lights, accessories) than that would point me to the dreaded TIPM and a chip in it. Only the dealer can tell you about this one.
Keep us informed.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 12-11-2013, 06:27 PM
Rep:38
Greg - You nailed it!
I just logged back in to tell everyone that I found out what it was. I checked each fuse, one by one to be sure I didn't miss anything. Turns out I did - it was Fuse #66 - SunRoof! I don't have a sunroof in mine, but that's thepurpose of the wire, as Greg noted.
I'm pretty damn excited that it isn't anything worse!
Next question - Where the hell do you get fuses?! I have gone to Home Depot and an Auto Store and neither have the tiny little fuses that go in this truck. The Auto Store guy said he has never seen them before...ugh.
Old 12-11-2013, 09:43 PM
Vehicle: .
Rep:4371
Diagram
Connection (SP2229)
Keep us informed.
Greg
Reps for hitting that one on the nail, nice
Old 12-12-2013, 05:18 AM
God Bless Texas!
Rep:2929
Voonderbar! Thanks for the update!
Old 12-12-2013, 08:25 AM
gcscott's Avatar
Rep:1043
Until you find a fuse at the store, you can use one of the extra ones in the fuse box that you don't have an accessory installed. Look around there are extra fuses in there.
Glad that fixed your problem.
Greg
electrical issues, radar detector install, wiring harness
