Old 12-07-2013, 08:39 PM
MC61RAM1500 MC61RAM1500 is offline
Vehicle: 2011 Ram 1500
Color: Dark Green/Tan
MC61RAM1500 is on a distinguished road
Default Attempting to do the Uconnect update
I'm brand new here and have searched the Ipod problem and have downloaded the Uconnect update to a clean FAT32 formatted flashdrive and plug it into the glovebox of my 2011 Ram 1500 and it keeps saying something like please plug flashdrive into the USB and try again. I gave up a nice GMC that played my Ipod flawlessly to this Ram that I can't get to work. Other than this I love the truck over the GMC. Any suggestions appreciated.
Old 12-08-2013, 04:51 AM
thebluegoat thebluegoat is offline
Color: Deep Water Blue Pearlcoat
Rep:49
thebluegoat is on a distinguished road
It was a couple months ago I did mine but I believe once you plug it in you need to hold down the uconnect button on the radio for about 15-20 seconds to get it to initiate the update. Mine works flawlessly since doing the update.
Old 12-08-2013, 08:53 AM
I've tried that and it gives me that message and shuts off so I try it again and it keeps doing it over and over but I can see the flashdrive flashing when I plug it in and hold the button down.
Old 12-09-2013, 08:22 AM
xsdbs xsdbs is offline
Vehicle: green flying carpet
Trim Level: upper and lower
Rep:73
xsdbs will become famous soon enough
can you drop you glove box down toward the floor and look inside the dash cavity to the far right side, you'll see a black module about 4" x 6" there. That's the Uconnect module, can you take a picture of the module and post it so we can see the PN & the SW version? Which link are you downloading the instructions from? (which posting)
Also what is the exact wording that is being said? There's a couple different error messages and the correct fix depends on which message that you're getting.
Old 12-11-2013, 12:42 AM
Hopefully the pic attached and the exact message is "please attach usb mass storage device with update file to system connector and try again".
I downloaded the file from the Iphone and Ipod sticky thread and I think it was a link to mediafire to the uconnect update. If pic doesn't attach it says HW:13.04 and SW:43.01.10
Old 12-11-2013, 08:29 AM
Rep:73
I don't see the picture but the provided info helps. I have 2 sticky threads for the 2011 Uconnect SW updates. I think that the one that you're trying to download from is;
http://www.ramforumz.com/showthread....connect+update
Is this correct? If so then the issue is most likely because the 1st update hasn't been done yet. I have another sticky with both updates and instructions. Please try it and let me know how it goes:
Old 12-11-2013, 09:18 AM
After trying it again the first update I need is the one I downloaded. I reformatted the flash drive again and downloaded from that sticky thread but the results are still the same.
Old 12-11-2013, 12:02 PM
Rep:73
So then you have already performed the first update that came out for the 43.1.10? There are 2 updates and you can't do the one for streaming audio sound quality if the first one isn't done (the first from the 2nd link that I provided). One way to find out if the first update that came out is done is to use and iPod or IPhone. Plug it into the docking cable, does Uconnect read and start playing with no issues? If it does start playing within a reasonable time frame then the 1st update has been done and we need to look at why you can't do the streaming audio update.
When you look at the file on the thumb drive after downloading it from mediafire, what is the file name?
Old 12-11-2013, 01:06 PM
When I plug my Ipod into the port in the glove box I get the error reading message and the file I downloaded was uconnect.upd
Old 12-12-2013, 08:41 AM
Rep:73
OK, with the "error reading" message, this tells me that the first step update has not been performed yet. Please go to the second link that I posted and walk thru those steps, ok.
.upd is correct
on some earlier 2011 vehicles, the extension had to be changed from .upd to .upn. but I think that you need to do both updates.
