Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 12-08-2013, 02:19 AM
tminor tminor is offline
Vehicle: 1997 Dodge Ram
Color: Blue
Rep:139
tminor will become famous soon enoughtminor will become famous soon enough
Default Electric fans
Looked through a couple pages in here and didn't see anything about this yet.
Got a 97 1500 with the 5.2L. I've heard of people swapping this stock fan to an electric 16", but is that really enough cooling power?
-Minor
Old 12-08-2013, 04:50 AM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Yes, it is. And you'll gain about 10 HP, at least, from the engine not having to turn the fan.
Old 12-09-2013, 10:16 PM
MOP4RN4TION's Avatar
MOP4RN4TION MOP4RN4TION is offline
Vehicle: 1996 Ram 1500
Trim Level: 1500
Rep:387
MOP4RN4TION is just really niceMOP4RN4TION is just really niceMOP4RN4TION is just really niceMOP4RN4TION is just really nice
is a single 16' better than say a dual electric setup?
Two things are infinite: the universe and human stupidity...― Albert Einstein
Old 12-09-2013, 11:51 PM
God Bless Texas!
Rep:2929
You'll probably get more total area using a single that you would a double because of the housings.
Old 12-10-2013, 12:39 AM
Color: Blue
Rep:139
thanks for the help man.
i was actually gonna ask about a dual set up, but i didn't see myself going that way anyways cause all the duals i've seen are like $400. thanks but no thanks haha
-Minor
Old 12-10-2013, 12:55 AM
God Bless Texas!
Rep:2929
Any time, my friend. Keep us in the loop of what you end up with.
Old 12-14-2013, 11:11 PM
Lazarus Truck Lazarus Truck is offline
Rep:194
Lazarus Truck has a spectacular aura aboutLazarus Truck has a spectacular aura about
I would stay with the stock "clutch-style" fan, unless its broke. Cost wont make it worth it. These were designed to tow a load, uphill, in the desert, and still do the job. The fan does a fine job of cooling during regular use. When a rapid rpm increase is desired, the clutch will slip, allowing the engine to spin-up, without the drag of the fan. After a few moments, the rpm will either decrease, or the the fan will catch-up to the motor. Great design. An electric fan would cause drag on the motor through increased alternator load. There is NO free lunch. Power is required to drive a fan, be it mechanical or electrical.
Another problem with electric fan retrofits is that the sizing and shape of the shrouds are not always optimal. A missing, or poorly designed shroud can undo all the benefits of any upgraded cooling components. Simply, if it aint broke, don't fix it.
The difference between genius and stupidity, is that genius has it's limits. A. Einstein
Old 12-14-2013, 11:32 PM
God Bless Texas!
Rep:2929
Good, sound advice.
Old 02-16-2014, 10:32 PM
Harley Harrold's Avatar
Harley Harrold Harley Harrold is offline
Vehicle: 2007 Dodge Ram 1500 Quad Cab
Trim Level: SLT Longhorn
Color: Detonator Yellow
Harley Harrold is on a distinguished road
You should check out the Flex-a-lite 183 E-Fan, it flows 3,300 Cubic Feet per Minute and uses only 18 Amps of power. This will be going on my 2007 Ram.
