Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 12-08-2013, 07:34 PM
toprjf739 toprjf739 is offline
Vehicle: 1997 Dodge Ram 1500
toprjf739 is on a distinguished road
Default Stereo upgrade
I've got a 97 Ram 4X4. I would like to upgrade the radio, but I do not like the aftermarket radios. I want one with an AUX input for my iPod. Can I install a radio from a newer model Ram? One that has the AUX input. I want it to look as stock as possible.
Old 12-08-2013, 08:35 PM
Rep:2616
I am not sure, but you might measure a radio from another Ram, up to & including the 2008 model Ram, anything newer then that will not work in your Ram
you can do some research by going to this website & then shop around for the best prices
http://oemautopartsco.com/
looks like the website only goes back to 2002, but you may be able to use it as a reference
it looks like right around 2002 is when Chrysler radios started using a cd player
the radios mount positions also changed around that time
I see you live in the general Oceanside area
you may want to hit a couple of the wrecking yards up there, or drive down to Otay Mesa road by the Brown Field airport, there are about 30 wrecking yards there & even more near there on Main St. & Nirvana in Chula Vista
Ecology i believe still has 1/2 prices on rain days & the day after
there is one other place that you might check, be prepared to have your ear filled with information the old guy likes to talk
Down by the Spring Valley Swap Meet, there is a Chrysler only wrecking yard, it is at 6301 Quarry Road, Spring Valley, CA at the old railroad xing. it is called SWEETWATER AUTO WRECKING, you should see a Dodge Ram or 2 out in front
Google it
https://maps.google.com/maps?ie=UTF-...d=0CI8BEPwSMAs
Good Luck
