broken wire ? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 12-08-2013, 10:47 PM
doobie23 doobie23 is offline
Vehicle: 2006 Dodge Ram 1500 quad cab
Trim Level: laramie
doobie23 is on a distinguished road
Default broken wire ?
ok first off. 2006 dodge ram 1500 quad cab 4wd Laramie trim. has the hemi.
I was underneath the front of the truck checking things out and noticed a wire dangling on the driverside front wheel. 2 wires inside a jacket. my question is whats this wire for? I found the other end and it goes to some type of sensor behind the rotor. I thought abs but they not one on passenger side. I can splice these back together until I can order one just don't know what to order. thanks.
2006 Ram Winter D.D,2000 Dakota Show Trk & Summer Ride
1952 Dodge B-3-B summertime project
Old 12-09-2013, 08:25 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:452
hydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of lighthydrex is a glorious beacon of light
Think you could reconnect with a good heat shrink crimp connector. Might point it out to the dealer, next time you take her in. Could be part of stability control, abs or something important. If I have a question about my brakes, I drive on a dirt road and stomp on the brakes. Should be able to easily tell if abs is ok.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's, Helwig rear sway bar,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 245,000 miles To Hell and back. 14.2/96 mph NEDW
Old 12-09-2013, 11:27 PM
Trim Level: laramie
Yea when I get a chance to get it in dry. Going to fix with heat and splice. Just curious what it is. Its been like that for 6 or more months. I had axles replaced and think thats when they did it.
Old 12-13-2013, 09:13 PM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Did you get the wire spliced? Did it fix anything. Or have you figured out what the wire is for? I'm thinking maybe a speed sensor or something for the ABS. Were you able to test the ABS out?
Old 12-13-2013, 10:07 PM
Simple guy Simple guy is offline
Vehicle: 2003 Ram 1500
Trim Level: SLT QC 4x4
Color: Mineral grey
Rep:109
Simple guy will become famous soon enoughSimple guy will become famous soon enough
its most likely a wheel speed sensor for traction control.
