A way to update Radio and Nav on 430N RHB! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 12-09-2013, 08:32 PM
discodan0 discodan0 is offline
Vehicle: 2012 Ram 3500
Trim Level: Longhorn
Rep:13
discodan0 is on a distinguished road
Smile A way to update Radio and Nav on 430N RHB!
I have been doing some research on how to update the Maps on the 430N RHB.
This is the somewhat easy way to do it. (or just less painful)
This is for someone who knows his way around a computer.
1. First you need a copy of the radio software update. (I used the last 50.00.07) It will be usually in .ISO form. I found it easily doing a google search.
2. Download the latest copy of Garmin City Navigator North America NT Unlocked. (I used 2014.10) You can find it on most torrent site.
Here is the tricky step:
3. Mount the .ISO file on a virtual drive (I used Daemon tool. Its free) and open it to see its content. Copy all the file to a new folder on your computer. Lets call this Folder "Radio Update"
4. Copy the file gmapsupp.img from the newly download folder "Garmin City Navigator North America NT" to the folder called "Garmin" inside the "Radio Update" folder. Once copied inside the "Garmin" folder, rename it gmapprom.img. (the one inside the "Garmin" folder)
5. (optional) if you have the junction view files, create a folder called JCV folder inside the "Garmin" folder and copie the JCV file in there.
6. Now you need to burn the content of the "Radio Update" folder on a DVD. Burn all content and not the "Radio Update" folder.
7. Insert the DVD in the radio unit and wait for a long time. It took me almost 2 hours to complete all updates.
Do this update with the vehicle running or a charger on the battery. You can not interrupt the process. Starting the vehicle will interrupt the process.
It did not ask me for a code for the maps.
This process updated all my maps and the radio software at the same time.
I tried to make those instructions easy.
Last edited by discodan0; 12-09-2013 at 08:48 PM. Reason: spelling mistakes and missing words
Old 12-10-2013, 11:23 AM
Rep:13
This should be moved to general discussion.
My mistake.
Old 12-27-2013, 05:42 PM
hoyter hoyter is offline
Vehicle: '11 1500 sport 4x4
Trim Level: sport 4x4
Color: mineral grey
Rep:13
hoyter is on a distinguished road
This worked for me. It took 5 days and about 10 hours to get it all figured out but I was able to update the Garmin map on my 2011.
I had 50.xxxxx and had to downgrade to 33.xxxx. From there I was able to load the Garmin map file from USB to my device. It took about 40 minutes to save. I was then able to update back to 50.xxxxx
All in all, I had several failed attempts with an unlocked map until I did some digging on some less than reputable sites to understand some of the Garmin lock/code issues. This is where the extra hours came in.
In the end, I have 2014.10 Garmin maps updated on my RHB with the updated Junction views. No luck on custom voices yet. It is WONDERFUL to be able to get around the costly and outdated maps that you buy from Mopar. By that I mean legally acquiring the Garmin city navigator map and then hacking it up to get it to load on the system is cheaper.
Old 01-05-2014, 11:54 PM
krc1075 krc1075 is offline
Vehicle: 2012 Dodge Ram 1500
krc1075 is on a distinguished road
Where can I get 2014.10, can you provide a link?
Old 01-08-2014, 01:38 AM
Color: mineral grey
Rep:13
Try to look around on p2p/torrent sites.
I downloaded an unlocked version, but I did receive an error when I tried to load it. The radio prompted an error asking for the unlock code. This might have been due to my error somewhere. I found had to find a key generator for the maps on the web and used a tool to code the key into the map file. From there it loaded without any errors.
Old 05-30-2014, 09:51 AM
M.Scipione's Avatar
M.Scipione M.Scipione is offline
Vehicle: 2011 Ram 1500 Crew
Rep:41
M.Scipione is on a distinguished road
I've read pages and pages on this at the Jeep message board and am still confused about the exact files I need.
I go here... http://gpsunderground.com/forum/garm...2014-40-a.html
and there are a million files listed.
I don't know what I need, I'm guessing "Map source data" & "D1279210A.JCV"
Is this right?
Old 05-30-2014, 12:42 PM
Power247's Avatar
Power247 Power247 is offline
Vehicle: 2012 Ram 2500
Color: True Blue
Rep:22
Power247 is on a distinguished road
So, once I go through all of this will it work on multiple vehicles? Both our vehicles are '12s and have the 430N radio. I was able to perform the upgrade to 50.xxx with the same setup disk I cretaed.
Greg
2012 2500 4x4 CTD Big Horn CCSB 3.73|Flo~Pro|SIMS|XRT Pro|Edge Insight CTS|Infinity|JBL
2009 1500 4x4 HEMI Big Horn CCSB 3.55|Volant CAI|18" Magnaflow|Airlift1000|Superchips Flashpaq 3865 - SOLD
Old 05-30-2014, 05:27 PM
M.Scipione's Avatar
Rep:41
yeah it'll work on both, you will have to roll back the firmware version to 33.xx.xx first... then update maps... then reinstall firmware version 50.xx.xx
Old 08-18-2014, 02:22 PM
boomboy2011 boomboy2011 is offline
Vehicle: 2011 Dodge Ram
Color: Blue
boomboy2011 is on a distinguished road
anyone can put the map update file for the rhb 430n on here ?
thank you
Old 10-31-2014, 08:30 PM
daveyjones daveyjones is offline
Vehicle: 2011 Dodge Ram 3500 Laramie
Engine: 2011-2012 409ci (6.7L) Cummins Turbo Diesel 350hp 800lb/ft
daveyjones is on a distinguished road
1st I updated to 33.xx.xx.xx.xx using dvd
2ng format usb fat32 using the 2014.2 gmapprom.img from TPirateB and JCV D3060130A in root dir of the usb
Garmin/gmapprom.img and Garmin/JCV/D3060130A
the JCV should be in the same folder as the gmapprom.img
find the nav id number its 10 digits long in the about section in the nav settings and then using map id 3047 generate key its 25 digits long
3rd tried 2014.2 with JCVd306...130a map and pnd successful
4th I had to use the jetmouse to get a serial code it worked like a charm
How to easy get unlock code on the 430n go to nav details and get the NAV Id # its 1234567890 total of 10 numbers
load Jetmouse go to custom map set enter your NAv Id and the Map Id for the Nav map your using (ex. map 2014.4 is 3187)
5th using a Kingston data traveler 8 gig the usb stick has to be since win 7 first came out I used it as a boot usb for years I don't think the speed of the usb really matters
6th leave vehicle off put usb stick in front of deck and turn vehicle on
to run position do not start vehicle the 430n will boot the usb automatically reading files for about 15 mins or so then will say you want to update maps press yes another pop will come up say you have to purchase the update contact Chrysler
hit ok and the 25 digit bar comes up with the code
9th enter the code you got with the jetmouse and that should start the nav update 1/1 no matter which file I download it asks for a unlock code in
9th map update complete pnd update complete
enjoy
I also did the 2014.4 from GPSUG and the JCV D3060130A with (map id 3187 for jetmouse to get unlock code) the same as above without a hitch and update to 50.0.xx.xx.x using dvd page 3 off the private server
thanks to all that put in the effort its frustrating and if it doesn't work reread the entire thread you will get it I had to read it about 6-8 times to catch it all
I do believe most people are using the wrong img to try and update using only this or that check what software is installed already on the 430n and match it directly
if it says NORTH AMERICA or LOWER STATES OR CANADA AND ALASKA use the correct img
this whole process once I had the img files, firmware updates 33.xx and 50.xx, and jcv took about 2.5 hours
the whole process to get the files read to get it all done to this point was about 8 hours
and No I have not bothered to go any further with the 2015.1 or .2 files my map was 2011.1 its a totally different system no more blue screen not driving off the road into nothing
good luck
files to get
2014.4 maps
City Navigator North America NT 2014.40 dl the Image City Nav north america NT
JCV
D3060130A.JCV
Get it here http://download.garmin.com/support/2.../D3060130A.JCV 796.76MB
ALL maps and IDS
ozboss | tomtom, garmin
new 50.00.07 firmware
NEW software update MyGIG 430N / RHB-RBZ 50.00.07
older 33.01.23 firmware
New Software Update MyGIG RBZ-RB2-RHB / 33.01.23 - Jeep Garage - Jeep Forum
Oldest RHB_E_23_4
http://www.mediafire.com/download/rj...RHB_E_23_4.iso
Jetmouse
JetMouse Garmin Keygen v1.5 with Checksum Fix
map update, nav update
