Old 12-10-2013, 09:50 AM
dodgeitri's Avatar
dodgeitri dodgeitri is offline
Trim Level: Sport Crew Cab
dodgeitri is on a distinguished road
Default Bullring Retractable Tiedown
Has anyone tried installing the Bullring restractable tiedown on a '13 with the spray on liner? Just curious if its fits and how difficult it was. Some sites are showing part 4001 as the one to use. Others say 2013 doesnt have one.
Thanks
http://www.bullringusa.com/shop/bull...ble-tie-downs/
Old 12-10-2013, 10:37 AM
Raz6200 Raz6200 is offline
Vehicle: 2013 Dodge Ram Crew Cab
Trim Level: Outdoorsman
Color: True Blue
Rep:61
Raz6200 will become famous soon enough
Thanks
Not sure about the spray in liner, but I have them in mine with the aftermarket liner. I just needed to user a razor blade to cut out the square line around the hole. Took a little while as I didn't want to make a mistake and start mangling the sides of the truck. They work pretty good and I like the look
Old 12-11-2013, 10:22 AM
i.am.zed i.am.zed is offline
Vehicle: 2013 Ram 1500 4x4
Color: Mineral Gray
i.am.zed is on a distinguished road
Are you concerned with the bed rail caps? The spray on bed liner shouldn't have any effect on this. At least it didn't for me.
I used part number 4001 on my truck. The OEM rail caps came with the back holes already open. I only put the Bull Rings here, not up front which would have required some cutting with a razor blade. Installation was a snap and took less then 10 min for both.
Old 12-11-2013, 10:34 AM
theGSE10's Avatar
theGSE10 theGSE10 is offline
Vehicle: 2013 Ram 1500 4WD Crew Cab
Color: Maximum Steel
Rep:33
theGSE10 is on a distinguished road
I have them on mine with the original plastic side covers and they fit fine. They were like $25 from Home Depot, and a 5 min install tops. Work great, just wanted another tie down point. I have Line X but only underails....either way I don't see an issue with them fitting on an overrail spray if that's what you mean. They have an adjustable depth.
Hellwig Sway Bar, Green filter, Borla XR-1, Line-X, Bak RollX, JBA TCC Shorty's, Raptor 4" nerf, Hunter Bull Bar, 20" Cree LB, Moroso Catch Can, Bilsteins @ 2.8, Fox 2.0 rear, TGC 1.75 spacer, Air Lift 1000, Bak Box 2, Trinity T1000
Pics: https://www.dropbox.com/sh/ut4enlwx4fslgd8/slpdRXv6z2
