Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Old 12-10-2013, 02:39 PM
cparsonsdc cparsonsdc is offline
Vehicle: 2013 Ram
Trim Level: sport
cparsonsdc is on a distinguished road
Default best leveling lift kit for 2013 1500 crew cab?
New to the forum and looking for kit for Christmas, suggestions without looking through all posts? Thanks
Old 12-10-2013, 05:39 PM
asavet18's Avatar
asavet18 asavet18 is offline
Vehicle: 2014 Ram 3500
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
Rep:19
asavet18 is on a distinguished road
bilstein 5100 adjustable shocks
Old 12-10-2013, 06:15 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
Yup, what he said ^^^
Check out the guide to leveling & wheel and tire sizing linked in my signature below.
Old 12-10-2013, 07:21 PM
Vehicle: 2013 Ram
Trim Level: sport
Thank you! Will post before and after pictures when done.
Old 12-10-2013, 07:37 PM
Vehicle: 2013 Ram
Trim Level: sport
ok Brandon, now I have a question, the bilsteins are the shocks for leveling? and the lift was an RCX? I am sorry for sounding ignorant, but I just want to make sure I get the right things!
Old 12-10-2013, 08:02 PM
Firemedic10584 Firemedic10584 is offline
Vehicle: 2016 Ram 1500
Trim Level: Sport 4x4
Rep:163
Firemedic10584 has a spectacular aura aboutFiremedic10584 has a spectacular aura about
If you are a 2wd, then you can not get the bilstein shocks. They are for 4wd only. If you're a 2wd, a 2" coil spring spacer off ebay will be fine.
Old 12-10-2013, 08:06 PM
13HemiRam's Avatar
13HemiRam 13HemiRam is offline
Color: Flame Red Clearcoat
Rep:58
13HemiRam will become famous soon enough
+1 on the bilstein 5100s!
2013 Hemi 4x4, 3.55 anti-spin, spray in bed liner, Husky liners, 5100's, Flowmaster 50 HD, Tinted tails, Federal M/T, inTune DCX, Green air filter, Amsoil XL
Only little boys wear bowties
Old 12-11-2013, 03:33 AM
Moderator
Rep:2140
Yes the Bilstein 5100 adjustable shocks can be used to simply level a truck and can be used to level off a lift kit properly as well. Most guys set them at 2.1" or 2.8" if they are just leveling a truck. With a 6" lift setting them at 1.4" will generally level it and with a 4" lift setting them at 0.7" should level it.
Check out the guide to leveling linked in my signature below. It has a whole explanation on the Bilstein shocks.
