Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 12-10-2013, 09:29 PM
elinmon1976's Avatar
elinmon1976 elinmon1976 is offline
Vehicle: 2004 Ram 1500 quadcab 2wd
Color: tan
Rep:65
elinmon1976 will become famous soon enough
Default help with front end "bump"
I need a little help. 04 2wd quad cab 1500.
I have a almost constant bumping in the left front wheel. If it were a 4wd I would say it was a CV axle but that isn't the case. I haven't had a chance yet to pull the wheel. Where would you guys start? Ball joint?
2004 Quad cab 2wd 4.7L
1998 Ram Reg Cab, 5.2 auto 2x4
Flowmasters to make her rumble...LOL
Old 12-11-2013, 12:53 PM
age525's Avatar
age525 age525 is offline
Vehicle: 2006 Dodge Ram 1500
Rep:91
age525 will become famous soon enough
It could be a bad tire or maybe the tire is off balance. I would try rotating the tires to see if that changes things. If not then check the bearings ball joints and other moving parts.
S&B Cold Air Intake, American Racing Headers, DB Performance Cat Back Exhaust, Recon LED Taillights, Bilstein 5100's, Toyo Open Country AT 2, Diablosport Predator, Recon Line of Fire, JL Audio 10W3 StealthBox, Alpine iDA-X305s Head Unit, Detroit TrueTrac
Old 12-18-2013, 06:45 PM
AFMEDIC's Avatar
AFMEDIC AFMEDIC is offline
Vehicle: 2002 Dodge Ram
Color: Maroon
Rep:18
AFMEDIC is on a distinguished road
I know it sounds weird, but check the brakes and make sure a pad isn't hanging up. That was the problem with one of our firefighter's dodge truck. He greased the pins and good to go.
If Guns kill people, then pencils misspell words and spoons made Rosie O'Donnell fat...
Old 12-18-2013, 10:17 PM
claymansrt claymansrt is offline
Vehicle: dodge
Trim Level: big horn
claymansrt is on a distinguished road
I second that, my pass front caliper had a siezed guide pin on the caliper and it would hang up and make a 'thud' when it released. caliper hardware kit, some grease, adn about an hour of work and it was fixed.
scammed by casper97ta! Don't buy from him!
Old 12-18-2013, 10:47 PM
RogerRamJet's Avatar
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Is it a rotational bumb? There's already been some good advice posted, but let me recap. Rotate the tires and see if it follows, if it doesn't, then it's isolated to the left front. Check the brakes next. If it's not rotational, it could be a ball joint, a loose shock or a something else that is loose.
Old 12-29-2013, 11:02 PM
G36Rick's Avatar
G36Rick G36Rick is offline
Vehicle: 2003 Ram 1500 SLT Extended Cab
Trim Level: SLT "Lonestar"
G36Rick is on a distinguished road
Is it over bumps ? certain road surfaces. Sounds like the sway bar links. Drove me nuts for quite some time. removed the sway bar,did a short road test and it was gone. replaced both links and was silent as as church mouse. Takes about 30 minutes to replace both. Rock Auto I would recommend,get the Raybestos profession grade, they are greaseable. Hope this helps !
