Old 12-11-2013, 08:33 AM
Firemedic10584 Firemedic10584 is offline
Vehicle: 2013 Ram 1500 Sport
Rep:120
Firemedic10584 will become famous soon enoughFiremedic10584 will become famous soon enough
Default 9006 bulb doesn't fit??
Ok, so I was going to switch out my current 5K HID bulbs in my fogs for a set of 6K to match my headlights. The current bulb in there now is a 9006 and locks in and fits perfectly. I ordered another set of 9006 bulbs and they didn't lock in correctly? I thought maybe a fluke so I ordered another set from another vendor. Same thing, the 9006 isn't locking into place like it should and the bulb is still kind of loose. My current 9006 bulbs fit perfect. Any ideas? I don't want to keep wasting money trying to get the right color temp bulbs that don't fit
Old 12-11-2013, 09:14 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
Switch the rubber O-RINGS on the bulbs. That should tighten up the bulbs.
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 12-11-2013, 11:10 AM
Rep:120
Greg
How I didn't think of that I do not know..... Lol. I shall try that!
Old 12-11-2013, 03:32 PM
gcscott's Avatar
Rep:1043
Sometimes it's the simple things that allude us.
Greg
Old 12-11-2013, 03:47 PM
Rep:120
That didn't work...
Old 12-11-2013, 05:51 PM
chuck2417 chuck2417 is offline
Vehicle: 2013 Ram 1500 Quad Cab Sport
Rep:158
chuck2417 has a spectacular aura aboutchuck2417 has a spectacular aura about
Does it come forward and backwards, up and down? Just wondering how exactly it's loose. I have 9006 bulbs (6K) in my fogs and I want to get 5K bulbs. The ones I got from HIDSRUS fit fine, no issues. They don't move. Take the bulbs out and take a look to see if something looks off, tabs or rubber part etc... Only thing I can think of.
Old 12-11-2013, 06:05 PM
Rep:120
The only way I can describe it is you know how when you twist in the bulb to lock it in? Well these new bulbs, when you twist them, they don't snug down like the current ones do. And the way they sit, the whole bulb will bounce/move going over any type of bump. I do notice that the 3 tabs that you have to insert a certain way into the fog lamp, those tabs are smaller than the current light. Not sure if that has anything to do with it but both of my replacement sets (from 2 different companies) are that way
Old 12-12-2013, 05:53 AM
gcscott's Avatar
Rep:1043
The only way I know of is to get thicker O-RINGS. The tabs on the bulbs should be the same size and in the same location on all the bulbs.
You have 3 different bulbs to compare, so you should be able to see what the difference is between them.
I had to put the O-RINGS from the 9600 Halogen bulb on my 9600 HID bulbs to make them fit tighter.
Hope you figure it out.
Greg
Old 12-12-2013, 08:13 AM
Rep:158
Where did you order the HID lights from? Like gcscott said all 9006 bulb tabs should be the same size. When I put mine in I never did move the o-ring from the halogen light to the HID. Mine seem to be in there alright. If it warms up a bit this weekend I'll take a look at the bulbs in my truck's fog lights again.
Old 12-12-2013, 09:57 AM
Rep:120
Well, all of my bulbs came from ebay dealers. But the original set I got had no issues. Just these 2 other pairs for some reason. Maybe just a fluke and i got the wrong bulb size....twice!
