Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Towing
Old 02-01-2014, 10:34 AM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:358
Depends. If you are buying new your dealer will take care of that for you. If you buy used have the seller throw in the whole wd hitch. They are adjustable and you will set the drop down where you need it.
333Half the beast
I used to be
Old 02-01-2014, 01:19 PM
smurfs's Avatar
smurfs smurfs is offline
Rep:105
smurfs will become famous soon enoughsmurfs will become famous soon enough
Originally Posted by Jedispiff View Post
I have my 2500 Cummins and am currently in the market to buy a camper. Which size receiver, ie dropdown, should I buy for the truck? I'm for sure getting a 2in ball on it. Thanks
Get a 2 5/16 ball.
Old 02-10-2014, 03:15 PM
movierunner's Avatar
movierunner movierunner is offline
Vehicle: 2014 Ram 1500 QC
movierunner is on a distinguished road
Originally Posted by Sideshow48 View Post
I was really impressed with the OEM brake controller as well on mine compared to my previous 2005 with aftermarket controller. I tow my 29BHS Jayco in full auto, using the tow/haul mode when bucking a wind or in hilly terrain.
Hello, I only bought my Ram before Christmas & not towed yet. Looking forward to using the OEM controller, I have the 5.0 Uconnect radio and was playing around in the trailer section. But I guess I have to wait untill I have trailer hooked up to the truck to do the set up. Did pick Trailer #1- use this trailer & it shows "electric light". have not seen where you can mane the trailer yet. I have a 2011 KZ 261RK and loaded would be around 6700lbs and use an Equalizer WD hitch. My old 2003 1500 QC towed this very well. Is the set-up (not the gain setting) easy to go through. Dealer really doesn't know any thing about it.
Thnaks
Old 02-16-2014, 12:44 PM
CrazyCanuck's Avatar
CrazyCanuck CrazyCanuck is offline
Vehicle: 2012 RAM1500 Crew 4x4
Trim Level: Outdoorsman
Rep:260
CrazyCanuck is a jewel in the roughCrazyCanuck is a jewel in the roughCrazyCanuck is a jewel in the rough
Any camper other than a tent trailer almost certainly have a 2-5/16 ball and should use a weight distributing hitch. Hitch height of the camper will determine what dropdown you will need, all WDH's that I've seen are height adjustable but you should still measure the hitch height of the camper (with the camper level), the height of your receiver tube (with your truck empty) and take those measurements to an RV or hitch place to ensure you get one that is suitable. There is no 'standard' height for camper hitches.
2012 RAM Outdoorsman
Factory Mopar Tube Steps, Spray-In Bed Liner.
Added Roll'NLock Tonneau, SwingCase Tool Box, Shattered window puck decal
Old 02-18-2014, 07:10 PM
Philpaint Philpaint is offline
Vehicle: 2014 RAM 1500 4X4
Rep:16
Philpaint is on a distinguished road
OP, do you have air suspension?
Old 03-04-2014, 12:13 PM
rammtber rammtber is offline
Vehicle: 2014 Ram 1500 Crew Cab 2wd
Color: Grey / Silver
rammtber is on a distinguished road
Nope, no air suspension.
Old 03-17-2014, 08:59 PM
gsalgado's Avatar
gsalgado gsalgado is offline
Trim Level: Tradesman
Color: Western Brown Pearl
gsalgado is on a distinguished road
I need to get myself some toys to haul
Old 03-17-2014, 11:15 PM
C2Hemi's Avatar
C2Hemi C2Hemi is offline
Vehicle: 2013 Ram Crew 4x4
Rep:13
C2Hemi is on a distinguished road
This is very good advice. I just switched from a Tahoe to a Ram. The Ram is taller and the wd hitch doesn't have enough drop. The result is either the front of the TT is high or the rear of the truck is low. I'm in the market for a new shank.
If your not mak'in a mess, you're not do'in it right
Old 04-03-2014, 09:07 AM
Originally Posted by CharlieL View Post
We tow our 24-foot trailer (5,100 lbs loaded) with our 1500 Laramie with 6-speed & 3.92 rear. It's a vast improvement over the 2004 Dodge Dakota! The factory brake controller is much superior to the prodigy I had in the Dakota. Having the controller integrated through the EVIC is just sweet! This summer we took a trip from Albuquerque (home) to Portland, OR. Total was 5,000 miles, and covered some flat areas and lots of hills. I found it towed fine not in tow/haul mode in full auto & using cruise on the flats & using tow/haul helped alot in the hilly areas. In neither instance did it hunt for gears.
Tell me how was setting up the factory brake controller? I have not hooked up the camper yet (too much snow) but hope to in the next few weeks. In the 5.0 radio I see where you pick the trailer & type of brakes, but have not seen where you can give it a name. Once set-up does it always show in the EVIC? and what info does if give you? Can't wait to tey it out......come on spring!!!
Thanks
2011 KZ sportmen 261RK, EQ hitch.
Old 04-03-2014, 10:58 PM
Rep:16
I don't think you can give the trailer a name. I did saw that in the F150
