Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 12-12-2013, 05:37 PM
03Rammer's Avatar
03Rammer 03Rammer is offline
Vehicle: 2003 Dodge Ram
Color: Tan
03Rammer is on a distinguished road
Default Ball Joints and Control Arms
Is it worth my while to purchase upper control arms instead of trying to press in new ball joints on the old ones?
I've been looking online and it seems that its a real pain to swap these out. I do want to make sure to replace them with greaseable ones. It doesn't seem right that they can be sealed and never need servicing...
Should I go ahead and replace upper and lower and do the tie rod end at the same time?
What are your thoughts?
Old 12-13-2013, 08:17 PM
AFMEDIC's Avatar
AFMEDIC AFMEDIC is offline
Vehicle: 2002 Dodge Ram
Color: Maroon
Rep:18
AFMEDIC is on a distinguished road
Yes. I just did mine a few months ago and man what a difference it made. I would do it all at once. Anything you do with ball joints will alter the alignment, so anything that would require an alignment should be done right now, that way you only have to pay for 1 alignment instead of multiples as you do things. I went ahead and did a torsion bar crank on mine and I love the way it sits now. It only took a few hours to do upper and lower ball joints and control arm bushings on both sides of the truck (using the upper control arm replacements)
If Guns kill people, then pencils misspell words and spoons made Rosie O'Donnell fat...
Old 12-17-2013, 09:38 AM
03Rammer's Avatar
Color: Tan
AFMEDIC - Thanks for the info. I can handle a few hours for sure. Replacing everything is what I was leaning towards. What brand of ball joints and control arms did you use?
Old 12-17-2013, 05:35 PM
bparsel bparsel is offline
Vehicle: 2014 Ram
Rep:15
bparsel is on a distinguished road
Go with Moog, they are serviceable to make things easier in the future.
Old 12-17-2013, 05:44 PM
TJC.geotech TJC.geotech is offline
Vehicle: 2014 Ram 1500 Crew
Color: Granite
Rep:114
TJC.geotech will become famous soon enoughTJC.geotech will become famous soon enough
The reason they sell the entire control arm these days is because it is very easy to distort them when you're taking the old joints out.
Old 12-18-2013, 09:06 AM
03Rammer's Avatar
Color: Tan
Thanks guys. Sounds like I've got my project arranged for January. I appreciate the help.
Old 12-18-2013, 07:42 PM
AFMEDIC's Avatar
Color: Maroon
Rep:18
I used the expensive autozone ones with a warranty (My step-dad is a manager there) and they have been great. The lowers are greasable, but the uppers are not. It is a considerable price difference for the greasable uppers, you might as well just run it for 5 years and replace them again! Make sure when you get the lowers, you buy 90 degree offset zerk fittings. You cannot get a grease gun on the straight ones with the front axle. Its a tight fit with the 90 degree ones but they work. only added another $2 to the project
Old 12-30-2013, 12:11 AM
G36Rick's Avatar
G36Rick G36Rick is offline
Vehicle: 2003 Ram 1500 SLT Extended Cab
Trim Level: SLT "Lonestar"
G36Rick is on a distinguished road
I replaced my whole entire front end on my '03 last December. I went with the Moog uppers (wishbones,with ball joints)). I made them greaseable by drilling with a stop drill,installed self tapping zerks $2.50 for a package.Worked like a charm. Just remember ,prior to installing the zerks, to clean and flush the joint of drill shavings,there won't be much. Then Grease when installed and your set.
Old 07-07-2015, 03:56 PM
03Rammer's Avatar
Color: Tan
Finished this up a while back and just wanted to give an update.
Ended up going with ProForged upper control arms with the upper ball joint (has a grease fitting).
Lower ball joints were easier to get out then I had been told! Ended up folding the retainer lip up on the back of the ball joint and pushing them right out. Cleaned up the ball joint hole in the lower control arm and the ProForged fit very snug and had a retainer clip on the back. Maybe took 2 hours total.
I also ended up replacing my lower end link kit on my anti-sway bar and new bushings on the frame and links.
These really tightened up the steering like it was new!
2003 ram 1500, 2wd, 4.7 287, control arms, upper ball joint
