ABS Issue - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Electrical
Old 12-13-2013, 10:04 AM
09HemiCrew 09HemiCrew is offline
Vehicle: 2009 Dodge Ram
Rep:75
09HemiCrew will become famous soon enough
Default ABS Issue
It was about -15°F the other day and I went out and hopped in my truck to leave work (mind you I was planning to go get a trade value for my truck…) and as I took off my rear wheel spun a little kicking the traction control on. At that moment, all the lights for: brake, abs, ESP, BAS, traction control lit up on my dash. OK, not a big deal, I will go read the code, it is probably just a speed sensor or something. The only ABS code I got was a C2200, which is basically a general code for the ABS module failure. There is a TSB that says there is a condition where this could occur and cause the lights to all come on with the C2200 code. The TSB says the ABS module must be flashed. I haven’t found any record of anyone actually getting this done.
Has anyone actually had this happen and had the dealer flash the module with success? I am likely going to take it in on Monday, but wanted to throw this out there. I am far out of warranty, so I am just trying to get a feel for how bad I am going to get bent over. The timing was impeccable…I was going to go get a trade value on a new Ecoboost….maybe the Ram gods are trying to tell me something?
2009 Crew Cab 4x4 Laramie - 4.56 gears, Detroit Truetrac, Diablosport Trinity
Old 12-15-2013, 08:04 AM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Take the hint, Dood! If the computer doesn't sense anything on start up, the light should go out on it's own after 4 or 5 starting cycles.
Old 12-15-2013, 09:29 AM
Rep:75
Haha. Hint taken. More of a vent as I hate taking my vehicles in. I can usually fix things on my own, but I've checked everything I can on this. Need the Chrysler scanner, I'm afraid.
Old 12-17-2013, 04:10 AM
Rep:2968
Excellent! Let us know how it turns out.
Old 01-11-2014, 10:35 AM
king0145 king0145 is offline
Vehicle: 2009 Ram TRX4
Trim Level: TRX4
Color: Yellow
king0145 is on a distinguished road
I have the same issue with my 09. When it snowed last week I was out and spun which kicked the traction control on then the dash lit up. I hooked my scanner up to it and retrieved the C2200 code. Please let us know if you find out there's another fix besides replacing the abs module. Thanks
Old 01-11-2014, 11:37 AM
Rep:75
The way I read the TSB's, they could have updated the ABS module to fix the problem BEFORE it occurs. If the lights are all on with the C2200 code, the module is shot. I bought one on eBay (new) and had my dealer program it after I installed it. They charged $99, but beats paying them way too much for the part plus labor for the 5 minutes it takes to install.
Old 02-04-2014, 03:16 PM
Trim Level: TRX4
Color: Yellow
I had the ABS module replaced last week which fixed my problem
