Old 12-15-2013, 10:09 AM
joestevens87 joestevens87 is offline
Vehicle: 2008 Dodge Ram 1500 4X4
Trim Level: SLT Big Horn Edition
joestevens87 is on a distinguished road
Default Heater Fan Not Working At All
I have a 2008 Ram 1500 Quad Cab and when I started it up this morning the heater fan would not come on at all. It was working fine yesterday and I have not had any issues with it in the past. Hoping it may be just a fuse or something. Any other ideas of a possible cause?
Old 12-15-2013, 12:51 PM
frenchy's Avatar
frenchy frenchy is offline
Rep:12
frenchy is on a distinguished road
Hi, I would start by trying all the fan speeds, if only a couple speeds work you need a "blower fan resistor" located near your fan blower or attached to the blower (usually under the dash passenger side). If nothing works,checked for 12V+ power (ignition ON and blower switch on any speed) at the blower connector, if you dont have power at all checked your fuse, if you do have power and nothing works unplug the blower connector and plug it back, sometimes the blower starts working again but it means it needs replacement anyways.
99% of the times it's either "the blower fan" or the "blower resistor", I've been a mechanic for 16years now and never had any wiring issues, sometimes the switch is defective but rarely.
Old 12-15-2013, 01:26 PM
thkbaron thkbaron is offline
Vehicle: 2011 ram sport crew 4x4
Rep:61
thkbaron will become famous soon enough
ditto to what frenchy said. I think I blew 3 or 4 resistors on my 2004 dakota. eventually they determined the wiring harness going to the motor needed replacing. must have been a short in it. no problems till the day I sold it.
2011 Ram Sport 4x4 Crew Cab
Old 12-20-2013, 05:16 PM
I replaced the blower motor myself this morning and all is working again. Easy 15 minute swap out. Thanks for the reply frenchy.
Old 12-28-2013, 09:02 PM
AFMEDIC's Avatar
AFMEDIC AFMEDIC is offline
Vehicle: 2002 Dodge Ram
Color: Maroon
Rep:18
AFMEDIC is on a distinguished road
check for recalls and TSB's if it happens again. I believe there was some kind of service message on these trucks to run a larger gauge wire from the ignition circuit to the blower motor. Im not certain on the years, but I know that my 2002 had it done. The original wires are dead in the harness and the dealership installed 2 new wires.
If Guns kill people, then pencils misspell words and spoons made Rosie O'Donnell fat...
