Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 12-17-2013, 05:31 PM
jchop90 jchop90 is offline
Vehicle: 2013 ram express
Trim Level: 1500 express 2wd
Color: deep cherry red
jchop90 is on a distinguished road
Default How do you launch your truck?
Hey guys i was wondering how every one launches their truck at the track? i just have the stock 3.55s and when i do run im still on the stock 275/60's. I just got the bully dog tuner and have been doing some test and my trap speed has gone up but im still running the same times as when the truck was stock, 9.4s and 9.5s. How can I this thing off the line? Thanks for the info in advance.
Old 12-17-2013, 05:37 PM
jsettle's Avatar
jsettle jsettle is offline
Trim Level: Sport 4x4
Rep:212
jsettle has a spectacular aura aboutjsettle has a spectacular aura aboutjsettle has a spectacular aura about
On my 2005 that I no longer have I would burn the tires a bit before getting to the line (makes them sticky), then stage at the lane. I would load the engine by holding the brake and getting the RPMs between 2k-2500. When the light goes green or the flag drops release the brake and punch it!
6" ProComp lift with ProRunner shocks, limo tint, 35x12.5x20 Hankook DynaPro M/T, 20x10 Fuel Hostage wheels with -24mm offest, 50" LED light bar with roof mount.
Build Thread: http://www.ramforumz.com/showthread.php?t=160442
Old 12-20-2013, 06:51 PM
Hornet Hornet is offline
Vehicle: 2014 RCSB 8sp/3.21 geared Ram
Trim Level: Sport 4X4
Rep:488
If you don't mind some work before,when you're in the pits.
An old drag racers trick on a rear wheel drive vehicle is to take the top rubber washer off your front shocks,and re-install just the nut and steel washer loosely.
This lets the front end come up an inch or more instantly,before it hits the shocks resistance and front end rise rate slows.
Helps transfer the weight onto the rear tires faster.
Might not do much ,but it doesn't cost anything to experiment with either
Only do at the track though,re-install the rubber washer and tighten the nut back down when you hit the street again
Old 12-21-2013, 02:25 AM
I ran my quickest time the other night, a 9.3 with a 2.3 60ft. I have ran a 2.1 60ft before but ran a 9.4. My launches are getting better I'm just trying to find the sweet spot with this new tuner. I launched it around 2k the other night and it just blew the tires off, that is always fun. If can do that with some traction I will be good.
Old 12-21-2013, 05:52 AM
13HemiRam's Avatar
13HemiRam 13HemiRam is offline
Color: Flame Red Clearcoat
Rep:58
13HemiRam will become famous soon enough
Doing a burnout on street tires just wastes rubber. They won't get hot enough to give any noticeable traction. Street tire compounds are designed to run cool. They are an "A" temp rating....you would need something like slicks or drag radials with a "C" rating
2013 Hemi 4x4 (w/ factory exhaust manifold leak option!) 3.55 anti-spin, spray in bed liner, Husky liners, 5100's, Flowmaster 50 HD, Pro Comp 7031's, Federal M/T, inTune DCX
Only little boys wear bowties
Old 12-31-2013, 12:09 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
stalling up the motor will kick in torque management (I pedal at green), 275/60's and 3.55's are a bad combo for the track, if your running streets, lower tire pressure to 23-35 lbs..don't burnout on streets, maybe a few rotations to clean tires but don't smokem up..
Old 01-02-2014, 09:17 PM
bouf0010's Avatar
bouf0010 bouf0010 is offline
Vehicle: 2013 Dodge Ram 1500
bouf0010 is on a distinguished road
i read somewhere that the street tires will actually create an oily film on the rubber when doing a burnout that will be detrimental to traction at the track.
T-1000 HF 93 Tuned - S&B CAI w/custom air scoop - Moe's 87mm tb - Silver Ceramic JBA Shorties - Magnaflow Y-pipe - GT Custom 22" muffler - V6 E-fan mod - 180 t-stat - Catch Can - bielstein shocks - 2" rear drop coils - Cooper Zeon LTZ 305/55R20
Old 01-02-2014, 10:01 PM
I push the skinny pedal
Rep:3277
If you're on street tires just chirp them, you don't need to do a burnout, you just want to remove any loose rocks/grit from your rubber, not for traction, but the less of that stuff on the track the better for the higher power guys, it's more of a courtesy thing.
Bringing the RPMs up before launch will almost always pull timing as the traction control kicks in, unless you can completely (almost) disable it using a programmer. The best way to launch these trucks with traction control is to stage with a foot on the brake and hover over the accelerator, then just punch it on the second yellow while releasing the brake. My best 0-60 times used this method on an open diff 4wd QCRB before I started disabling the traction control.
The best way to get better launch times with your combo would be to get a much shorter tire. Those tires with a 3.55 diff are just killing you.
Kurtis
Old 01-03-2014, 07:27 PM
gsxrfarm's Avatar
gsxrfarm gsxrfarm is offline
Vehicle: 2012 ram express
Trim Level: express
Rep:47
gsxrfarm is on a distinguished road
about 2100 was my best spot as far as street.. if I could get the tires sticky 2500 is a great launch imo
2012 express , s&b cai, magnaflow, bullydog, catchcan 24" rims
Old 01-03-2014, 11:18 PM
chefred112's Avatar
Rep:656
on our trucks if you remove the front sway bar the truck will squat at lunch...
