Old 12-18-2013, 07:55 PM
ericlee9386's Avatar
ericlee9386 ericlee9386 is offline
Vehicle: 2011 Dodge Ram
Rep:36
ericlee9386 is on a distinguished road
Default Lean misfire help
Hello all. I am in need of some help. I have a 11 ram 5.7 with 6.4 cam. 2 month ago my truck started having a p0302 misfire code. I changed all the plugs. It went away and then came back. So I changed the swapped 2 and 4 coil and injector still no change.( I didn't check compression because the cylinder is still hot when I put water on the header tubes.) < Is this a accurate statement? The truck will idle rough early in the morning but will clear up as I start driving.
A new problem is now starting were the truck will stall early in the morning when it is cold. If I drive for awhile the truck will drive just fine. Every now and then it would stall after a trip down the interstate but its rare.
A little background that may help. The first time I tried the cam install I broke the rocker arm shaft and bent a pushrod. I drove the truck 100 miles with the rocker arm broke and the tops of the valve stems are rather beat up.
So question number 1 is
1. Do I need to check compression
2. Is there a chance I have bent valve or leaky valve? An how do I Check them?
Thanks
Performance mods
2800 stall, moes ported throttle body, vararam intake, ARH LT, Flowmaster 10 series, Hemifever tune.
Best 1/4 mile: 14.30 @91 mph soon to be 13's
Old 12-19-2013, 04:32 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:441
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
Has hemifever looked back at the tune? Any chance of a vaccum hose being loose or fallen off? AIT sensor? Interestingly, I just had a spartan plus installed in my 05 and at first, it hated cold weather, it would stall unless I kept my foot on the gas for 30 seconds or so. My dyno tuner (TDP in Steuben,Maine) told me to bring it back for a tweak to the tune. A couple of cold days, down to -8F and the ECM has learned the cam, it runs perfect now. Adaptive learning. As far as screwing up the valves, hmm, I'd be checking the compression and I'd think about replacing that peened valve. BTW, TDP welds in a bung for a wideband and data logs, sends to hemifever for adjustment, then we dyno and datalog until the a/f ratio and knock retard among other criteria make us happy.
Inertia Spartan + cam, Circle D 3,000 stall ,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf,Line-X Bedliner,GY Armortracs, 230,000 miles To Hell and back. 14.2/96 mph NEDW
Old 12-21-2013, 05:22 PM
Brandon .30-06 Brandon .30-06 is offline
Rep:29
Brandon .30-06 is on a distinguished road
It's a possibility you have a bad lifter. I've done 6 trucks this year that have had lifters go bad. The truck will have an engine noise if it is the case.
Brandon
Level 4 Chrysler tech
Old 12-21-2013, 06:25 PM
Rep:36
Brandon
I don't have any engine noise that seems out of place. The truck runs great as long its moving. Its only running rough at idle and while cold. If it was something with the valve train shouldn't there be a sign? Is it possible that a o2 sensor could be stuck rich or lean causing my problems?
Performance mods
Old 12-21-2013, 06:37 PM
Rep:36
I am planning to contact Sean but I wanted to ensure I didn't have a mechanical issue. I was planning to check compression today but its raining pretty bad here so no go. But since the header tube is still hot like all the others isn't that a sign there is no valve train issue?
Performance mods
Old 12-21-2013, 10:12 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
are you able to datalog? do you have a scanner or diablo that can log af ratio while at idle or when it's close to stalling out?
Old 12-21-2013, 11:01 PM
Rep:36
Yes I have the trinity. What should I be looking for in the logs? I usually watch the fuel trims, o2s, MAP and several other things.
Performance mods
Old 12-22-2013, 12:26 PM
Rep:29
Id lean away from the O2 sensor as you would probably get a code. all the trucks ive seen pretty much loose a cylinder and it shows a misfire. from what your saying it sounds like your lifters are ok
its kinda hard to diagnose a vehicle without it infront of me
Brandon
Level 4 Chrysler Tech
Old 12-23-2013, 01:19 AM
chefred112's Avatar
Rep:656
what numbers are your fuel trims look like at idle or specifically when it's about to stall out...
Old 12-23-2013, 01:23 AM
chefred112's Avatar
Rep:656
my guess is that at idle the pcm is dumping fuel because of the cam and lt headers...any kind of hesitation will throw a misfire code..
