Old 12-20-2013, 08:04 PM
DarthRam's Avatar
DarthRam DarthRam is offline
Join the Dark Ram Side!
Rep:1534
Default 2500 Upfitter switch panel on 1500
I am planning on adding heated wiper blades to my 2013 1500 Sport Quad Cab. These are a simple 3 wire system (For the heated part) with a dedicated on/off switch.
I plan on ordering the 2500 upfitter switch panel Mopar part 68137100AD.
Thanks to Benny at www.MoparOnlineParts.com for finding the part number. I have found next to zero info on this. Everything I can find is on the single row AUX switches. I want to use one of the AUX buttons to turn the heated part of the wipers ON/OFF. The switch panel is $62 plus S&H. The blades are $140. I don't want to start throwing money at this if it can't be done. I like the OEM look and the ability to add up to 4 other items down the road.
Can I direct wire to these AUX switches (And an ignition power source) without relays, harnesses, modules and such?
Magnaflow 14" Custom Install Bilstein 5100s Front Only Set at 2.8" Vararam Air Grabber Cravenspeed Stubby Antenna Dee Zee Tailgate Assist Billet Technology "The Punisher" Shift Knob Debadged doors and tailgate Plasti Dipped HEMI Badge The Punisher Grille and Tailgate Badges Exterior Chrome Delete 20" XD Series 795 Hoss LT305/55R20 Nitto Trail Grappler M/T Cabin Air Filter BAKFlip Roll-X Tonneau Cover
Old 12-21-2013, 08:34 AM
gcscott's Avatar
gcscott gcscott is offline
Vehicle: 2013 Ram 1500 4X4 / 3.55 LSD
Trim Level: Outdoorsman Crew Cab
Color: Deep Cherry Red Crystal Pearl Coat
Rep:1043
gcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud ofgcscott has much to be proud of
At $62 I would think you are only getting the switch panel. You will need to add fuses and relays to the switches. I would not expect the switches to be high amp.
See what comes in the box.
I don't know if you saw this but it is similar to what you want to do. May give you some ideas.
http://www.ramforumz.com/showthread.php?t=106672
Greg
MOD LIST:To many to list. I do all MODS and Installs myself.
View them here: http://www.ramforumz.com/member.php?u=66037
Every time I think I'm done with doing Mods something else catches my eye.
Old 12-21-2013, 11:46 AM
DarthRam's Avatar
Rep:1534
Greg
I did see that but he was starting from scratch. I have a powered panel already minus the AUX switches. I was afraid I was going to need to add the fuses and relays. I even saw some vehicles come with an Upfitter Module. Hopefully those are just for ambulances and those kind of vehicles.
Old 12-21-2013, 11:55 AM
DarthRam's Avatar
Rep:1534
I did some more research. It seems to make these AUX switches work I need the AUX Power Distribution Center (68049500AB) which is a $400 part. Well I guess I am going to look for a single switch and drill a hole in the console somewhere. I knew it sounded too easy to just switch panels.
Old 12-31-2013, 12:50 PM
DarthRam's Avatar
Rep:1534
OK. I did some MORE research. I really think I can do this cheaper than I thought. I have sourced a fused relay box from Bussmann. I found a site that is one stop shopping for the box, relay, fuses, wire, and fittings.
Benny at www.moparonlineparts.com ordered a 2500 Switch Panel to make sure it is the part I need. Since there are no pictures to go with the part number. If you do a Google search it will bring you here.
So here is the price break down so far:
2500 Switch Panel $63
Mopar Wiring Kit $38
Bussmann relay box, relays, fuses, wire, and fittings $60
S&H should be under $10
So, all in I am looking at around $175 for a clean, OEM looking switch panel I can add things on to going forward.
It is more then I thought it would be going in. It is A LOT more then a $5 eBay rocker switch but no drilling in the dash.
Benny tells me the switch panel won't be in until January 20th or so. I am in no hurry since the only thing I can do until spring is pre-wire the relay box. It is a cool project but it's not a work in -25 temperatures cool with no garage.
So, stay tuned...
Old 01-12-2014, 11:55 PM
bendodge bendodge is offline
Vehicle: 2012 Ram
Rep:163
bendodge has a spectacular aura aboutbendodge has a spectacular aura about
Where did you find the Bussmann relay box, relays, fuses, wire, and fittings for $60
Old 01-13-2014, 05:37 PM
DarthRam's Avatar
Rep:1534
http://www.waytekwire.com/
Old 03-02-2014, 05:51 PM
DarthRam's Avatar
Rep:1534
A small update. I tracked down the guy who actually builds the Bussman relay terminal into a "turn key" setup. For $110 shipped I will get a 5 switch wired and ready for integration fused and relayed system for the the 2500 AUX panel.
Problem is he can barely keep up with demand and is on a 3-4 week backlog. Oh well, it's not like I can install it anyway considering it is 10 below right now.
I will post pictures of course when it shows up.
Old 03-03-2014, 09:17 AM
Vehicle: 2012 Ram
Rep:163
Can you pass along the name of the company that makes the turn key Busseman set up ?
Old 03-03-2014, 03:45 PM
DarthRam's Avatar
Rep:1534
The company is Wired Wagon. The owner is Erik Johnson. His email is:
wiredwagon(at)comcast(dot)net
