Old 12-21-2013, 08:25 AM
jasonec500's Avatar
jasonec500 jasonec500 is offline
Vehicle: 2012 Ram 1500
jasonec500 is on a distinguished road
Default Front end alignment
Is it normal for the suspension to make a popping noise right after an alignment? It only did it four times and only while making left turns, but it was quite loud. I had just left the dealer from having it aligned when it made this noise and I immediately went back. By the time I got there it wouldn't do it anymore. Go figure. They couldn't replicate the noise. Anyway, the service guy said they put it back on the lift and checked everything over and found nothing wrong. He said sometimes the suspension settles after an alignment and to just keep an eye on it. What do you guys think?
Moroso catch can, Amsoil air filter element, Mufflex DOD24M
Old 12-21-2013, 05:04 PM
TurboCup87 TurboCup87 is offline
Vehicle: 2012 1500 Sport Crew 4x4
Color: Blue
Rep:28
TurboCup87 is on a distinguished road
The only time I've had significant noise after an alignment, they didn't fully tighten a camber adjuster. Made a significant knocking noise. It was not on my RAM.
If it doesn't persist, it's likely OK. Let us know what happens.
Old 12-21-2013, 06:31 PM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
imho, no, it is not normal.
Old 12-21-2013, 06:36 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2032
I agree with huntergreen, it's not normal. I had my 1500 aligned twice and didn't have any sounds afterwards. Maybe bring it somewhere else for a second opinion.
Old 12-21-2013, 08:56 PM
jasonec500's Avatar
I have a feeling I should have just left it alone. I've got a little over 17k miles on the original tires and started to notice slightly uneven wear on the drivers side. The passenger side was perfect. Do you guys normally get a print out of all the specs on each wheel after you get it aligned? They showed me the before, but nothing afterwards. I probably should have asked, but I just wanted to get outta there.
Old 12-21-2013, 11:35 PM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1109
I go to a place that gives me the results and even has a screen in the waiting room showing the progress.
Bilstein 5100s @ 2.1", CF wrapped dash, De-badged, Extang Solidfold tonneau, Goodyear Wrangler Duratracs (285/60/20), Husky Weatherbeaters, Magnaflow 18" muffler, Mufflex 5" tips.
Old 12-21-2013, 11:48 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
It does not sound normal to me as well. See post # 17 in this thread http://www.ramforumz.com/showthread.php?t=143779, you will see my before and after alignment numbers following installation of my bilstien levelling struts.
Old 12-24-2013, 08:07 AM
Trim Level: sport
Color: green
Rep:657
any update op ?///////
Old 12-29-2013, 09:00 PM
jasonec500's Avatar
I've been driving it every day since. Put about 40 miles a day on it with no obvious issues so far. We'll see what happens. I'll post when I rotate the tires next time and see if there is any noticeable wear.
